Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Removing Focal ES100K tweeters from their housings
      01-17-2017, 08:43 AM   #1
SteveEvans
45
Drives: E92 M3 Coupe
The procedure for removing Focal KRS 100 tweeters from their housing is shown HERE.
I've just received my Focal ES100K speakers and found that tweeter disassembly is a little different, so I thought I'd capture it here.
With the tweeter sat on a flat surface simply press down on the collar bearing the FOCAL logo.
This will simply unclip as shown below.
It can then be slid off the bottom of the tweeter and over the cable. The mesh grill then lifts off. Note that it's made of steel and so is quite strongly attracted to the speaker, so as you lift one side the other will get pulled back by the magnet. Just be careful not to allow it to be pulled into contact with the cone!
You'll then be left with the component parts thus. I'll be picking up the BMW E92 speaker housings tomorrow and will report back on how the tweeters fit into those.
As an aside, at this point I'm tempted to replace the wire soldered to the tweeters with the 16AWG silver plated copper that goes from the amp into the door. Not sure if it's a good idea for the sake of 6" of wire. Thoughts?
Steve
      01-17-2017, 01:11 PM   #2
SteveEvans
45
I should add that this is described in the manual that comes with the speakers. Also note that there is a collar which must be fitted to the tweeter in order to provide clearance between the diaphragm and the BMW housing.
Steve
      01-18-2017, 02:17 PM   #3
SteveEvans
45
I'm afraid it's not good news. Focal, I hope you're reading this...
The rings supplied by focal for fitting the tweeters are ID 41mm to fit snugly (more on this later) the tweeters, their OD is 44.75mm. The BMW tweeter housing has an ID of 43.8. No way would that tweeter/ring assembly fit in there no matter how much brute force and ignorance I applied.
So, 3D printer time. New ring on the left, OD 44mm, Focal ring on the right.
Second issue is that a mere press fit of the aforementioned collar just doesn't cut it. I considered a collet style collar to lock the tweeter into place once inserted into the BMW housing, but that was getting a bit fiddly. I don't intend removing these... so CA adhesive, very carefully applied to the collar before pressing the tweeter into it, ensured that collar is going nowhere.
It then snapped into place a treat.
And I now have a yellow tweeter awaiting fitting to the car.
I'm lucky to have a 3D printer to sort out such things. I think Focal need to do a little more to make life easier for us BMW owners!
Steve
      01-18-2017, 02:28 PM   #4
SteveEvans
45
Oh, and Focal, should you read this, then on a related note, please provide some decent adaptor rings for the mid-range too. The ones I had supplied with my ES100Ks (not Focal rings) were "nasty".
So, time for more ingenuity... and a wait of about 4 hours.
Fortunately Focal provide a nice gasket with the speakers, which can be seen here fitted to my design of adaptor ring before fitting the speaker.
And then bolting the speakers into place with M5 countersunk bolts, thread locked , gives a nice assembly. The patterning on the face is just due to residues of a green print done prior.
I printed a mirror image so I can choose which orientation fits best to each door.
I can sell you the design if you like Focal.
Steve
      01-18-2017, 08:52 PM   #5
SteveEvans
45
Having assembled the tweeters into the housing I'm not happy with how the foam fits in the back. The tweeter, pushed back by the collar by 5mm is a bit too deep. I see no reason for the collar to be that deep apart from that being the depth of the recess in the BMW housing for the clips to hold.
A better solution is therefore a stepped collar, most clearly shown as a CAD drawing rather than the real thing:
The 2mm deep recess, 42.2mm ID, allows the tweeter to sit 2mm deeper, and still gives the latches the required 5mm depth of collar.
Steve
k335d80.00
      10-14-2017, 07:45 PM   #6
zequim
Drives: BMW 520d f10
Steve
Hi! Nice speaker plates!
Can I ask where did you get them?
Thanks.
      02-20-2018, 03:44 AM   #7
scanspeak
scanspeak's Avatar
Australia
354
Drives: BMW E92 325i 12/2007
Great job.
I'm about to begin a similar installation. Can I ask where you installed the crossovers and what switch settings you used in them?
      06-24-2018, 02:54 PM   #8
SteveEvans
45
See http://www.e90post.com/forums/showthread.php?t=1346848
      06-25-2018, 07:55 PM   #9
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
I swear Focal has a whole team full of people just making tweeter cup designs. I have last year's 100KRS and the cup is completely different -- but did come with instructions on how to pop it out.
      10-13-2018, 06:59 PM   #10
Puchok
Drives: BMW F10 520d M-Sport 2014
Very happy with your adapters, have no any issues to put on my BMW F10 door panel.
Here is some pic.
      10-18-2018, 03:57 PM   #11
SteveEvans
45
That’s great to see!
Thanks,
Steve
      10-18-2018, 07:55 PM   #12
bluewater328
626
Dang, the F10 really has a lot more room. Wonder if you could custom fit a 3-way in there.
      11-23-2018, 06:05 AM   #13
SteveEvans
45
See https://www.ebay.co.uk/itm/Focal-ES1...W/173656095958
Steve
      03-03-2019, 05:02 AM   #14
Wright83uk
Drives: E92
Focal tweeter rings
Hi. I am enquiring to where I can buy the rings Steve has made to fit the tweeters. Anybody selling them?
Thanks ian
      03-03-2019, 11:57 AM   #15
bluewater328
626
Thanks ian
You mean besides his ebay listing above?
https://ebay.us/PGfOVX
As an aside, TechnicPNP also has adapter rings that are a little more universal in nature.
      09-27-2021, 05:36 PM   #16
NickMSM
Drives: Defender
I don't suppose anyone has the ES100k tweeter grills and the surround stamped Focal going spare do they? Looking to buy some.
Tags
disassembly, es100k, focal, tweeter
