01-17-2017, 02:16 AM | #1 |
101
Rep 221
CEL with JB4
Hey Guys,
Installed a catless dp on the weekend. Been driving nicely, today had some issues however. I had a drivetrain malfunction pop up, turned the car off then on again (help desk lvl 1) and bam problem solved.. Is this purely the jb4 doing its thing or is this normal or..... Further, I had my jb4 drop the earth connection mid driving (after the above pop up). This caused Armageddon to occur. I think I seen Bruce Willis flash in front of me ever so briefly. Of course I had a million faults pop up which I can clear with torque pro. Im wondering would the JB4 dropping cause any problems besides the immediate loss of everything engine related and I come to a complete stop? Should I be worried about anything further? However, once I connected the wire and cleared the faults it seems alright. Cheers in advance. |
01-17-2017, 06:24 PM | #3 |
Joint Chiefs of Staff
24198
Rep 190,805
01-18-2017, 04:01 AM | #4 |
101
Rep 221
Hey.
I cleared them using the torque pro. I should have screen shotted them. Things like waste gate, o2 sensor, fuel rail. From what i recall was things related to where the JB4 connects into. I keep getting drive train malfunctions again today. Restarting the car solves the problem. Its like 40 degrees here tho at the moment, so maybe due to heat.? |
01-18-2017, 08:42 AM | #5 | |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
01-18-2017, 01:22 PM | #6 | |
24198
Rep 190,805
01-19-2017, 03:55 AM | #7 |
101
Rep 221
Update:
So haven't received any more fault codes since the JB4 disconnected. However the drive train malfunction again came up tonight, we can rule out heat as today dropped to a cool 20c so it cant be that. Weird thing is i didnt restart the car like i normally to do to clear the code. I open torque pro and no faults were found...... I dont have the USB cable to the JB4 so thats not a possible to grab the logs from there. I have also noticed a really faint nose coming from the engine bay when your off the gas since installing the DP, the noise seemingly goes away when im almost full lock with the wheels :s I would take it back to the dealer but now I have a dp so that kinda out of the question.. Could I have stuffed the dp install somehow? |
01-19-2017, 05:50 AM | #8 | |
Bright Sky
1164
Rep 922
As for the DP noise, maybe it's light burbling you would normally only get in sports? Since my DP was installed I can hear it very faintly burbling when my foot is off the pedal even in comfort. The noise would be coming from the exhaust then. I'm not sure what's causing the drivetrain malfunction and it's going to be very hard to determine unless you pull some more information from your car. You really want to read out the error codes when the message pops up. It usually goes a long way in determining what's wrong. If the downpipe is catless, it could throw a CEL, but I doubt the "catless downpipe detected" code would actually throw a drivetrain malfunction error your way as well. I am sorry, but all of this is pretty much speculation until we get some error codes or logs
01-19-2017, 12:34 PM | #9 | |
24198
Rep 190,805
you start by saying you have not received any codes since removing the Jb4 then you say you got drivetrain malfunction ... Get a code reader and check codes
01-19-2017, 02:36 PM | #10 | |
101
Rep 221
im not getting any codes that were similar to the ones the other day after the JB4 cut off, however Im still getting the drive-train one. Ill see if i can a code reader and gets some logs. |
01-20-2017, 05:03 PM | #11 |
101
Rep 221
Update:
So I wasnt able to get logs sorted from the jb so I have pulled the JB4 off the car as well as the CAI. I have a dp which ill be removing from the car as well but for the time being Im getting these codes through torque pro. I realize the Cat code is from the DP but the others im concerned about. Im getting drive train malfunction 100% of the time last few days. Current Fault Log ------------------ P007D: Unknown code - More information may be available on the web Pending Fault Log ------------------ P00BD: Unknown code - More information may be available on the web P0113: Intake Air Temperature Circuit High Input P0238: Turbo/Super Charger Boost Sensor "A" Circuit High P0420: Catalyst System Efficiency Below Threshold (Bank 1) Some quick googling of the circuit related one. States "A short to a power source in the sensor circuit can cause the ECM to get internally burned out if the circuit short goes over 5 volts" So My JB4 disconnected the other day because the earth and power connections some how touched in the engine bay, it was a super hot day and it seems the wires melted :s. Could this have caused the JB4 to short the sensors? Last edited by Amack; 01-20-2017 at 05:25 PM.. |
01-20-2017, 05:20 PM | #12 | |
715
Rep 1,541
01-22-2017, 02:37 AM | #13 |
340
Rep 716
Drives: F90 M5
^ this, check your chargepipe for cracks and stuff and put the stock intake back on and see if that fixes it
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
01-22-2017, 03:09 AM | #14 | |
101
Rep 221
have checked the pipes and fitted the stock intake. the air intake code has cleared but the turbo ones still remains. |
01-23-2017, 11:34 AM | #15 |
715
Rep 1,541
Which specific code remains?
01-23-2017, 07:26 PM | #16 |
16
Rep 42
P0238: Turbo/Super Charger Boost Sensor "A" Circuit High Circuit high means theres an open in the circuit which could be a severed wire or the shit just dont work anymore |
01-24-2017, 12:32 AM | #17 | |
101
Rep 221
I think when my jb unit crossed wires it may have shorted out sensors it's plugged into. |
01-30-2017, 03:22 AM | #18 |
101
Rep 221
update: taken the car into BMW, at the time only the below Fault code was present.
P0238: Turbo/Super Charger Boost Sensor "A" Circuit High & a powertrain fault, the others had cleared. BMW have sent away for a new Boost sensor. I explained that I did initially clear the codes in order to get the car running so I could drive home, they explained that and ODB app like torgque pro is enough to void warranty should they need to send something the Germany....... However in my case they are covering it. |
01-31-2017, 02:18 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Your dealership lied to you lol, typical bmw scaring tactics!
Find another mod friendly dealer and maybe jb4 is not meant for you
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
