01-11-2017, 10:33 AM | #1 |
2Addicts Member
13
Rep 23
M240 Dyno Testing
Just curious ... the M240 has been out for some time now and I don't see much out there on dyno specs for WHP & TQ. The M240 has a the new B58 engine, slightly larger turbo and updated pipe work to help cooling than the outgoing M235. The M140 w/ the same B58 engine posted 349 BHP and 384TQ on a dyno in the UK. Has anyone seen any credible dyno testing done on the M240?? To produce the stock 4.2 (0-60 time) and 12.7 (1/4 mile) it would seem to be producing more power than the factory stated 340 BHP / 370 TQ. Does anyone have any thoughts or know of any recent credible dyno testing?
01-11-2017, 10:43 AM | #2 |
2924
Rep 1,303
Drives: 2021 C8 Corvette 1LT
I'm schedule for an Insoric test on the 21st. It's a new method of measuring whp and wtq. Mine is xDrive though so won't be as high as others, but I'm hoping it's close to those numbers. The Insoric system has shown to be pretty damn accurate so I'm confident the numbers I get are accurate.
01-11-2017, 11:19 AM | #3 |
2Addicts Member
13
Rep 23
Thanks Joe240 for sharing your upcoming M240 dyno test later this month (Jan). Let the forum know what you learn. My goal is to make some sense of the published numbers on BHP & TQ vs the stated times posted by BMW and others. Something is not adding up when I see the 0-60 times and the 1/4 mile times. My guess is that BMW is understating the numbers slightly.
01-11-2017, 11:47 AM | #4 | |
2924
Rep 1,303
WillOs7.00 |
01-11-2017, 11:55 AM | #5 | |
1424
Rep 3,395
At least in my limited experience its a very small amount I'm grateful that they are conservative on estimates instead of the opposite.....thats for sure I'm itching for Dinan to release some goodies for the B58 |
01-11-2017, 01:46 PM | #6 |
89
Rep 246
01-11-2017, 03:15 PM | #7 |
2Addicts Member
13
Rep 23
Thanks for sharing. My assumption is soon we will have numbers that are consistent on the M240 (B58) given the number vehicles that are out there and the fact many are beginning to do tuning work now. It appears that BMW is conservative once again on the stock M240. There is a you tube video out there on the M140 (stock B58) on dyno. It pulled 349BHP / 384TQ which is about +3% / +10-15 over published. Great to hear the many positive comments on the M240. I have an M240xi scheduled for delivery in early March (Alpine White / Blk Leather / Blk Kidneys / Blk / Orbit Grey Wheels, etc.
01-11-2017, 05:41 PM | #8 |
689
Rep 908
Drives: '17 F22,15 E84 M Sport,02 R53
Agreed - if the B58 proves to be reliable and problem free we're in good stead. My 240i should be in my hands next weekend.
01-12-2017, 10:01 AM | #9 | |
243
Rep 447
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
01-12-2017, 12:00 PM | #10 |
2924
Rep 1,303
I've been thinking the past couple days about whether or not I should consider doing the Insoric runs on the factory 225/245 staggered 18s, or if I should stick with my 235/265 19s. Does the extra 1.5% rolling diameter difference make that big of a difference on the wheel power rating? I'm assuming since the Insoric system uses a center cap mounted sensor instead of rolling a drum that it wont matter much, but I could be wrong. Thoughts?
01-12-2017, 09:35 PM | #11 | |
20
Rep 48
http://www.caranddriver.com/features...d-tires-tested |
01-13-2017, 01:45 AM | #12 | |
2924
Rep 1,303
01-21-2017, 09:00 AM | #13 |
2924
Rep 1,303
SO the results are in. Just got home from my "Dyno" run using the Insoric Real-Power system. Pretty surprised with the performance since it was -1.5C out (about 29F for myself and my oddball American brothren who don't use the metric system).
Results below: 313PS at the wheel 363.1PS at the crank (estimated) 507.5Nm at the crank For us Americans, that's: 308.7 HP at the wheel 358.1 HP at the crank (estimated) 374.3 TQ at the crank Thought it was odd that they measured the car at 1830kg (just over 4k lbs), but it had a full tank of gas and the gentleman doing the run was probably around 180-200lbs as well so I guess it's not a bad measurement. These numbers are from a 2017 m240i xDrive U.S. Spec. So RWD will be higher and also in higher temps should also improve more. Overall, I'm very happy with the run and results. Last edited by Joe240; 01-21-2017 at 09:11 AM.. |
01-21-2017, 09:24 AM | #14 |
2Addicts Member
13
Rep 23
Joe240 - thanks for sharing your results. Sounds like you were happy w/ the 358 HP / 374 TQ. Your numbers are close to the recent M140 RWD dyno numbers in the UK (you tube video) which were 349 HP / 384 TQ. What is the primary difference / benefit w/ Insoric testing?
01-21-2017, 10:27 AM | #15 |
2924
Rep 1,303
Insoric uses a sensor on the wheel to calculate the numbers using angular velocity and other algorithms. The benefit to Insoric over a dyno/mustang jet is that the measurements are taken during normal driving conditions. With the dyno/mustang jet, it's on a machine with cooling fans blowing on the front of the car to simulate driving conditions. Some say that if there isn't proper cooling conditions then the numbers can be off. Also, some places don't adjust the barometric pressure and temperature settings when input into the machine. With the Insoric, they have an actual measurement tool that comes with the kit to measure current temp and barometric pressure, yielding more accurate results.
Plus it's Swedish made and they've never been wrong, right? And they make great products (watches, knives, banks) |
02-09-2017, 08:35 AM | #16 |
1424
Rep 3,395
02-09-2017, 10:49 AM | #17 |
2924
Rep 1,303
02-22-2018, 12:48 PM | #18 |
Rep 1
BMW M240 Baseline on mustang dyno
Here is my baseline on a mustang dyno at p3 import autoworks in alaska. The number next to it is my friends m235 (claims winter tires) 376 hp 363 tq
02-22-2018, 01:27 PM | #19 |
175
Rep 474
Yours is 376HP? What mods?
Looking for 335/n54
03-09-2018, 11:45 AM | #20 | |
89
Rep 188
