01-05-2017, 05:17 PM | #1 |
14
Rep 36
Best Catted Downpipe to run with MPE?
Hey guys,
I plan on getting MPE soon and was hoping to drop in a catted DP in the meantime. Anyone run a similar setup? How is the sound? There's lots of suggestions for Fabspeed/Wagner/ER etc. Is there a "consensus" on the best one? About me: DD the car about 60+ miles a day (very often in traffic) so can't have drone. Live in CA so emissions . . . Dislike CEL (plan on a tune much later when I've run the warranty) Thanks. Last edited by MeanMGN_F22; 01-05-2017 at 05:49 PM.. |
01-05-2017, 05:42 PM | #2 |
Joint Chiefs of Staff
24197
Rep 190,805
Our most popular is Wagner
01-05-2017, 07:00 PM | #3 |
3279
Rep 3,256
I went fabspeed. No cel and sounds fantastic! At some point I will put a vid up that I captured with a GoPro.
Fabspeed Motorsport1005.50 MeanMGN_F2213.50 |
01-05-2017, 07:20 PM | #5 | |
24197
Rep 190,805
Op, If you do not mind paying an extra $400, the HJS cats used in the Fabspeed downpipes are worth it
MeanMGN_F2213.50 |
01-06-2017, 12:01 AM | #6 |
14
Rep 36
01-06-2017, 12:39 AM | #7 |
89
Rep 310
The HJS DP is most likely to pass a smog if any as 300cell. the sound is great. I have it paired with an awe exhaust so will differ with an MPE. had the MPE without the DP, but don't think the DP will be much different in regards to drone with a catted and MPE
MeanMGN_F2213.50 |
01-06-2017, 01:47 AM | #8 |
39
Rep 103
hjs catted fabspeed. have mine paired with the MPE. the MPE is meh without an aftermarket DP. no cel yet.
MeanMGN_F2213.50 |
01-06-2017, 01:16 PM | #9 |
24197
Rep 190,805
You probably will not get a CEL ever
01-06-2017, 03:15 PM | #10 |
3279
Rep 3,256
MeanMGN_F2213.50 |
01-06-2017, 03:16 PM | #11 |
1006
Rep 1,653
Hands down our Sport Cat is the best on the market. I have one installed on my M235i and I absolutely love it. No CEL, no tune required! I have it paired with our Muffler Bypass Exhaust but I have heard it with the MPE and it sounds amazing!
Check your PMs, I would love to get you set up! |
MeanMGN_F2213.50 crbalch472.50 |
01-06-2017, 03:54 PM | #12 |
14
Rep 36
01-06-2017, 05:47 PM | #14 |
3279
Rep 3,256
Can confirm, no unwanted resonance inside the cabin. I actually have my valve unplugged to stay open on the MPE, but even if you found it to be an issue, you can always drive around with one valve closed in comfort mode.
MeanMGN_F2213.50 Fabspeed Motorsport1005.50 |
01-06-2017, 06:32 PM | #15 |
14
Rep 36
01-06-2017, 07:14 PM | #16 |
39
Rep 103
no drone, valve open all the time. have done several 4 hour driving sessions and 8k miles total so far with no cel.
the sound honestly is just the bonus that you get with the downpipe considering the much improved throttle response... |
01-09-2017, 09:57 AM | #17 | |
1006
Rep 1,653
Awesome! Let's get you set up! Thank you!! |
01-09-2017, 11:06 AM | #18 | |
228
Rep 301
You can check my install experience with pics here: http://www.2addicts.com/forums/showt...1323437&page=2 I'm running mine with stock exhaust and there is no difference in sound except at cold start up and WOT. No drone, No CEL. I will soon eliminate ASD & then decide of I want to enhance the exhaust with a modification. You need to keep your stock pipe. I'm also in Cali and you may or may not pass the visual inspection part of the smog test depending upon how observant the particular smog monkey you choose. It's best to pick an inspection station in an economically challenged part of town, and if smog monkey catches it; you can always try discreetly holding an extended $20 while saying something like, "you can clearly see that there's a catalytic converter and oxygen sensor in that pipe." If that doesn't work, then swap the stock pipe back in and then go back and pass the re-test. I think this is one of the best mods, bang for buck & should probably be the first mod made. |
01-09-2017, 12:51 PM | #19 | |
1006
Rep 1,653
ChrisFulton227.50 |
01-09-2017, 05:43 PM | #20 |
126
Rep 424
arghhh!! i am so wanting this. I just havent figured out if i want to grab a MPE, Dinan exhaust or do the muffler bypass by fabspeed with those beautiful carbon fiber tips...
Decisions, decisions..!!
2016 BSM M235i: Fully loaded. Dinan Stage II Tune, Dinan CAI, Fabspeed Sport Cat, Fabspeed Muffler Delete. |
01-09-2017, 07:05 PM | #21 |
24197
Rep 190,805
Get Fabspped catted DP + Fabspeed muffler Bypass
01-10-2017, 09:09 AM | #22 | |
1006
Rep 1,653
Check your PMs! |
xantdieselx410.50 |
Tags |
downpipe, mpe |
