What should I do next?
12-26-2016, 01:22 PM | #1 |
2032
Rep 8,339
Here's what I've done so far. Csl trunk and 1M front bump are being done in a couple weeks. What should i do next?
Some ideas I have: 911 front calipers and rotors Dynavin and stereo CF side skirt extensions CF front splitter Wrap Demon eyes and upgrade angel eyes M3 cowl Rear camber adjusters V35 or M3 CF hood P3 vent gauge What I have: Power: -2009 N54 Long Block for 6MT with 52k miles -Vargas stage 2+ turbos with 9 blade Garrett clipped turbos, 6x6 billet compressor, 20T drive gear -ER charge pipe with tial bov and Hobbs switch -VRSF catless downpipes -MMP inlet pipes -MMP outlets -VRSF 7" FMIC with aluminum downpipes -Motiv dual disc clutch and flywheel. 1000hp rated -Motiv fuel rail stage 2 -Fuel-it stage 3 double LPFP -Using e85 Electronics: -Juicebox 4 G5 with 2 step module, anti lag, 155mph defeat -MHD with Motiv/PTF tune by Jake -3.5 TMAP sensor -Valentine One radar detector hard wired -Laser Interceptor Jammers -Garmin GPS Hard wired -Smart Top module Chassis: -Wavetrac 3.08 LSD -Boost Addictions LSD lockdown -KW V2 coilovers with 1" front drop, 1/2" rear -M3/TRW front control arms -M3 Strut tower brace -Rogue Engineering transmission mounts -335is guibo -new driveshaft center bushing -AKG black subframe bushings -Stoptech drilled and slotted rotors, pads -BMS clutch valve and clutch stop Wheels and tires: -Avant-Garde M590 wheels in brushed antique copper 19x8.5 et.30 front, 19x11 et.43 rear -Bridgestone Potenza RE11 tires 245/35-19 front, 305/30-19 rear Exterior: -1M front Bumper with F12 6 series LED fog lights -CSL CF rear trunk lid with CF reveal -Msport rear bumper with gloss black diffuser -M3 replica side skirts -Rear fenders rolled and stretched -LCI LED taillights -Cree 160w angel eyes -15% window tint Miscellaneous: -M3 steering wheel with Alcantara trim -ZSP short weighted shift knob -NGK plugs -new hpfp -Serpentine belt -new power steering pump, lines, and fluid -new coolant lines -Walnut blasted -oil, oil filter, and transmission fluid changed -new oem engine mounts -Had all bushings checked and replaced as needed -New radiator, water pump, and thermostat done this year -new vacuum lines -new coolant overflow -new boost solenoids
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
12-26-2016, 02:34 PM | #3 |
2032
Rep 8,339
Some here on my build thread.
http://www.e90post.com/forums/showthread.php?t=1205124 |
12-26-2016, 04:55 PM | #4 |
94
Rep 447
I think your idea list is pretty solid.
Personally, I would go with just an LCI hood, or even a vented LCI hood. Maybe something like this, I think it's the duke dynamics D2 hood. Found an album of pics on their website: D2 Pic Album Last edited by noah.s; 12-26-2016 at 05:00 PM.. |
12-26-2016, 04:57 PM | #5 |
YouTube.com/TvTara
6456
Rep 4,715
Ooh, wrap it!!!
12-26-2016, 08:04 PM | #6 |
886
Rep 2,720
Read your thread...I would say...take a break, have a drink and sleep nice
You have put amazing mods and efforts... Great build But I must say, you are bad at pictures Post some good pics man !!! I would like to see some interior shots as wel. Enjoy your ride...Florida is the place for e93 |
Soles330i14.50 |
12-26-2016, 08:46 PM | #8 |
537
Rep 2,825
sounds like an awesome build.
I would debadge the 335i logo off the back, looks super clean and gives your car a great sleeper look. you can smoke the taillights - gorgeous on silver/white paint. you can perhaps add some carbon/black wrap accents around the car to compliment the white paint - again the contrast would look gorgeous. eg. carbon wrapped trunk, roof and rear decklid (looks wonderful if properly executed) carbon wrapped bottom diffuser, along with gloss exhaust tips. I may have missed it, but you can also modify your stock muffler if you want more sound? you 335i guys have a sweet sounding PE mod for your stock muffler. cheers! |
12-26-2016, 10:36 PM | #9 | |
4276
Rep 9,209
-F30 brakes and M3 master brake cylinder -M3 cluster especially since you have 155mph defeat installed |
12-26-2016, 10:47 PM | #10 |
2032
Rep 8,339
Hmmm. Good ideas. Can you tell me why f30 vs 911? I've been debating between the two.
12-27-2016, 08:18 AM | #11 | |
4276
Rep 9,209
