Windshield Washer Fluid Low Again?
12-21-2016, 08:48 PM | #1 |
26
Rep 62
Hi Folks,
Just filled up my washer fluid about 2-3 weeks ago (had the light come on), haven't used it much and I just the light on again. I don't see any fluid on the ground so I am wondering what it might be. Any common issues here? Cheers, Shinghi |
12-21-2016, 08:57 PM | #2 |
51
Rep 260
It's the washer pump in the passenger fender. Make sure you replace the strainer with it.
11 335D - BPC stage 2.5
13 X5D - Family hauler 01 Cummins 3500 - 1100 torques |
12-26-2016, 02:41 PM | #5 |
795
Rep 762
Washer pump is attached to tank and positioned between fender and liner behind pass front wheel.
kydiesel35166.00 |
12-26-2016, 10:42 PM | #7 |
277
Rep 1,575
01-04-2017, 06:19 PM | #8 |
26
Rep 62
Well I went out to fill it up just to make sure there was a leak and a bunch of it started coming out from below the passenger side headlight. Do you think this is the pump on the reservoir or something to do with the headlight sprayer. The car was parked on a hill so that could be part of it.
If it is the headlight sprayer, is it hard to replace or fix? Photo: View post on imgur.com Video: https://youtu.be/MxaS9GIlh_E Last edited by Major_90; 01-06-2017 at 11:43 PM.. |
01-11-2017, 10:59 AM | #11 |
14
Rep 117
http://www.etkbmw.com/bmw/EN/search/...79/61677157145
I have the same issue, not sure what to order - pump or reservoir, I guess it's needed to be determined with more testing. |
