BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Looks like we can adjust EGR flow via ISTA!!
      12-15-2016, 10:47 PM   #1
ninja_zx11
89
Drives: X5 diesel 2009
Today i was looking for actual vs requested boost values for my X535D in ISTA and i bumped into a setting for the adjustment of EGR flow control.I didn't try it but looks we can minimize the amount of EGR flow into the intake which can reduce carbon buildup.But i am not sure if the adjustment amount would be enough to prevent carbon build up.
Appreciate 4
      12-16-2016, 04:31 AM   #2
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
You really are a ninja.
      12-16-2016, 05:30 AM   #3
Pat_335D
Pat_335D's Avatar
20
Drives: 2010 335D
Looks like I'll be doing this today then hopefully!
      12-16-2016, 05:51 AM   #4
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
That is a pretty cool find! 40% is definitely better than nothing.
      12-16-2016, 10:11 AM   #5
JOHNNYBRAVO1
NY BRAVEST
47
Drives: 2010 Monaco blue, 335D
That's for non deleted EGR values?
      12-16-2016, 07:23 PM   #6
135i_vs_
135i_vs_'s Avatar
72
Drives: M5, 135i, 335d, F10 550xi
Great find! Try and and see if it works.
      12-17-2016, 08:19 AM   #7
AzRiz
AzRiz's Avatar
130
Drives: E92 M3 LE500
Awesome, did you find any difference in how the engine feels after doing this?
      12-17-2016, 10:17 AM   #8
Len_Beach
186
Drives: 435d
I've done this on my N57 Az although the settings for the N57 are 0-0.7 so 70% reduction.
I chose 0.7 naturally. The throttle response is definitely punchier and more immediate.
      12-17-2016, 10:44 AM   #9
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
      12-19-2016, 05:37 AM   #10
AzRiz
AzRiz's Avatar
130
Yeah man I knew that you did this a while back, I've been wanting to do it ever since, need to find someone near me in London to do it.
You also did the swirl flap delete and then experienced problems, is all that fixed now? Would you recommend doing this EGR change or do you think that may have contributed to the problems that you faced?
Thanks man
Progress Thread | Instagram: @azriz
      12-19-2016, 03:48 PM   #11
Len_Beach
186
Drives: 435d
Thanks man
I had the code throw up following the swirl flap removal which I've not been able to clear. There was no evidence of it in the drive of the car.
And to be honest; I had the same code prior to removal. The only difference was that resetting swirl flap adaptions cured the code. However the code is symptomatic of either carbon build up around the flaps preventing full opening or closure or a failed/faulting swirl flap actuator.
As my flaps are gone it's not actually an issue and the build up around them would have been a restriction.
I don't think the EGR adjustments would have any adverse effect. It should mean that carbon build up is diminished over time.
Put a post up for someone with ISTA nearby. Isn't Sensible from the coding forum near London?
      12-19-2016, 04:22 PM   #12
ninja_zx11
89
I tried and i was only able to set the low pressure EGR to +.40.Doing high pressure EGR gave me error.
      12-20-2016, 02:08 PM   #13
135i_vs_
135i_vs_'s Avatar
72
That sucks..but kind of makes sense from an emissions standpoint.
The low pressure EGR is only in the X5, and it is after the DPF, so relatively soot free. Therefore, adjusting it is probably allowed for slight emissions and performance.
The high pressure EGR should not be allowed to be adjusted. Violation of emissions laws.
It was too good to be true maybe
      11-14-2019, 05:45 AM   #14
Pete7811
Drives: E60 & E90 LCI
How did you get into this window? I have ISTA+ but can't find it...
