Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Delay in shifting
      12-14-2016, 09:02 AM   #1
JTC1
36
Drives: 2011 335d
Delay in shifting
This may be a stupid question, but humor me if you will.
I have noticed a slight delay in shifting going from second to third recently. I had the transmission serviced about a month ago and I know the adaptions were reset. My question is, could the delay be due to my driving style and the reset adaptions? I typically start from a stop really slow then once in second increase acceleration (habit from years of trying to achieve high gas mileage in the TDI). I don't always drive like a prick, but with the D I do enjoy having some fun sometimes. I only notice the delay at full or close to full acceleration. Does any of this make sense at all?
      12-14-2016, 09:41 AM   #2
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
I've only noticed the delay when car is stone cold. Even near new. It behaved no different in this regard before and after fluid change. I have deduced this to be a way to warm engine more quickly. I just hit the paddle shifter and go on into 3rd as I don't want to hear the engine race.
      12-14-2016, 10:07 AM   #3
dmanb2b
2125
Drives: G07, F97, F30, E90, E46, E30
I experience the same thing, especially noticeable when temps are near, below freezing.
      12-14-2016, 10:14 AM   #4
Mark M
Mark M's Avatar
240
Drives: E30M3 E83X3 E90335D
Similar behavior here. Believe this is intended function with torque converter slip to warm up the engine and trans.
      12-14-2016, 10:23 AM   #5
Bimmerguy1987
25
Drives: 1992 Chevy CK1500
Yes same thing for me, only below 35 deg is really noticeable, and only for a few up shifts.
      12-14-2016, 10:29 AM   #6
Fork!TheSpoonWrecker
Drives: 2009 335d - Monaco Blue Sport
Same thing for me, though when it does switch i find that its very sudden and jolts me when shifting. when its warm this doesnt occur. I usually just manually shift when i know this will be happening.
      12-14-2016, 10:34 AM   #7
135i_vs_
135i_vs_'s Avatar
72
Drives: M5, 135i, 335d, F10 550xi
Similar situation here, 91k on original fluid. BMW suggests change at 100k intervals as per manual.
Sometimes get a delay, almost like hunting for next gear, 2nd to 3rd. The way I have to eliminate this scenario is by letting slightly off the throttle right before I feel it will shift.
      12-14-2016, 10:34 AM   #8
charlie fairmont
472
Drives: His & hers, GC & X5
I just had mine serviced and have the same thing. Bit of a thread jack, but should I be concerned if adaptations weren't reset?
      12-14-2016, 11:45 AM   #9
rulonger
111
Drives: 2011 335d E90 & 2010 328i E91
+1 on the delayed shifts on cold mornings - I have noticed this delay on cold mornings. Go easy until the engine warms up and it should go away (mine does).
If you are noticing this delayed shift with a warmed up engine, it may be something to look into.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock)
      12-14-2016, 12:12 PM   #10
JTC1
36
Drives: 2011 335d
Resetting adaptions should have been a routine part of the service. I'd just give your shop a call and confirm they in fact do it.
      12-14-2016, 12:47 PM   #11
dmanb2b
2125
I'd change that fluid asap. ZF would recommend a 50K interval, although since you are almost at 100K an oil analysis would be really cool to see.
      12-14-2016, 12:48 PM   #12
GoRomeo
GoRomeo's Avatar
964
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Do you know what they did when they serviced it? changed fluid?
      12-14-2016, 02:45 PM   #13
lnxguy
357
Drives: 2009 335D
I get the same thing when the car is cold, I just ignore it.
'09 335D
      12-14-2016, 03:51 PM   #14
JTC1
36
Drives: 2011 335d
Changed oil and pan/filter with ZF parts I provided.
      12-14-2016, 04:10 PM   #15
JayNC335d
26
Drives: 2011 335d w/ Sport pkg
I to have the delay shift at cold. I always thought it was the normal characteristic of the transmission/programming. Though I assumed it was linked to the fancy exhaust... then again, I blame everything on that!
Slight tangential question. Like 135i vs said, I switch to manual mode. I don't have paddle shifters, but I shift manually about 80% of the time, DS 10%, and regular drive the remainder. Two questions for the people that actually know what they are doing, am I screwing anything up by "delaying" the perceived warm up by keeping revs low at inital start? And lastly, any negative thoughts on heavy usage of the manual shifter? (I mostly shift up, and rarely use engine break, if ever, to slow). Appreciate the insight and sorry for the tangent!!!
      12-14-2016, 04:37 PM   #16
Torqu3
321
Drives: 2011 335d
Is there something wrong with engine braking that I am unaware of?
      12-14-2016, 04:41 PM   #17
JayNC335d
26
Not sure, a buddy once put it to me, would you rather replace the power train or the brakes...
      12-15-2016, 07:04 AM   #18
BB_cuda
BB_cuda's Avatar
765
This
I can't answer your question from a trans fluid temp perspective. If trans is staying in 2nd to speed warming of the engine oil and coolant, here is something to keep in mind. I've read (and can't point to the source right now) that you shouldn't heavy foot until engine oil is warmed up (past what temp I don't know). Reason is the oil going to the turbos should be warm to take care of its oil seals. I go with around 65C. So, if you need to rocket onto the freeway, keep this in mind. I guess it would depend on how cool it is where you are and how far freeway is from your home.
A buddy at work has a turbo charged Subaru Forester and he told me the cluster shows a blue snow flake until its warmed up. I told him about the turbo oil seal.
      12-15-2016, 10:50 AM   #19
charlie fairmont
472
The vehicles are definitely not apples to apples, but I read a quote a long time ago from Tommy Archer that said his car doesn't move until oil temp is 130F
      12-16-2016, 07:27 PM   #20
135i_vs_
135i_vs_'s Avatar
72
The higher revs at cold start is strictly for emissions to warm up the catalytic converters as fast as possible. You are not harming keeping revs low, as drivers with manual transmission cars do it all the time. Nothing wrong with manual shifting, just might be changing the adaptive shift settings/pattern.
      12-16-2016, 07:53 PM   #21
atwal187
atwal187's Avatar
50
Drives: bmw 335d e90 2009
Is changing the pan/filter mandatory with flushing the transmission fluid ? BMW tech said they usually just flush the fluid only
      12-16-2016, 08:05 PM   #22
Thecastle
307
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
It's not mandatory, but recommended. Heck changing the fluid isn't mandatory it's lifetime.
Seriously though, the pan with integrated filter is like 120. Zf recommends replacing both the fluid and filter. I'm about to,do,it on my 335d, and I've done it on my X5 4.8i which has the same transmission. The X5 has 92k miles and shifts better now.
