Lets see those subwoofer setups
12-13-2016, 12:39 AM | #1 |
Rep 16
Ive never found a thread dedicated for subwoofer builds like there are wheel setups, although i've seen a fair amount of unique customs scattered across the forum. Interested in seeing what types of setups our cars are capable of.
Lets see what you got! |
12-13-2016, 01:42 AM | #2 |
1918
Rep 13,117
subwoofer threads
http://www.e90post.com/forums/showpo...2&postcount=66 http://www.e90post.com/forums/showth...t=Ultimate+Sub http://www.e90post.com/forums/showth...ight=subwoofer Last edited by ctuna; 12-13-2016 at 01:48 AM.. |
12-13-2016, 09:40 AM | #3 |
Bman's 328
Rep 25
Square operates box with two JL 12w3 V 3's and a JL JX 1000 . Amp has front mounted JL volume control so I can keep the bass where I want it and don't over power the rest . Next I will upgrade the rest of the speakers and the factory amp after Christmas when time allows .
Amp is mounted on the side of the box behind the front panel so it's all hidden |
12-13-2016, 10:45 AM | #4 | |
Rep 16
I have a single JL 12w6v2 powered by a MRP-m500 which makes for a decent combination. Leaning towards switching to two 12 Type Rs in the future. |
12-13-2016, 05:16 PM | #5 |
Bman's 328
Rep 25
I really like the JL amp.
This is where I put the amp volume . Also relocated the heated seat control to the ashtray location. I found a trim plate that didn't have the seat controls and added a USB charger . |
12-13-2016, 07:23 PM | #6 |
Rep 16
Interesting spot for the knob, looks nice. Did you run the wire through the center console? My current amp doesn't have support for a knob, which can be irritating for those songs where the bass is almost non existent.
12-13-2016, 11:49 PM | #7 |
63
Rep 307
My setup
I added my sub to the logic 7 system using the LC7i, love the sound quality. I am running a DD audio M1c 1700w with a pair of JL Audio 12w6 wired to 1 Ohm. I have the base control with the amp on switch for when I do not want to run the amp. Yes the amp will shut off with the car too. I have a 100 amp regular fuse off the battery going to a 100 amp resettable breaker. So I can cut all power to amp if needed. I also have a 2 farad capacitor to keep lights from dimming.
12-14-2016, 02:32 AM | #8 |
23
Rep 19
Here's mine. It's still a work in progress as I'm working on making the false floor and trim panels. There will be the obligatory RGB LEDs to light everything up. The setup has the three Kenwood 10s utilizing the storage well in a custom MDF and fiberglass enclosure that I built. I also made the custom amp enclosure for the Rockford Fosgate Power 1000 amp. This is all in my 2008 E91.
12-15-2016, 03:11 PM | #9 |
77
Rep 330
12-20-2016, 03:45 PM | #10 |
Bman's 328
Rep 25
I did run it from the front of the console . I had to modify the wood grain part of the console just a little but it all fits fine .
12-21-2016, 07:57 AM | #11 |
23
Rep 19
Here's how I treated the issue of where to mount control knobs.
12-21-2016, 02:10 PM | #13 |
300
Rep 3,969
Absolutely sick!!!
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-21-2016, 03:49 PM | #14 |
23
Rep 19
12-21-2016, 03:50 PM | #15 |
23
Rep 19
01-09-2017, 01:49 PM | #16 |
Lame Stance Dude
53
Rep 204
Here's my IB setup with an ID15D2 V3 sub and a Rockford Fosgate R500X1D:
A huge thanks to member kaigoss69 for walking me through the process via multiple PMs and answering my many questions. I think the end product turned out pretty nice despite some pretty basic cable management. In retrospect I probably should've tried to find some grey upholstery to match the trunk liner but the black isn't too bad. Not the prettiest but sounds great! |
01-10-2017, 06:49 AM | #17 |
4543
Rep 11,903
My custom set up - Ocky straps FTW LOL
01-10-2017, 10:24 AM | #18 | |
300
Rep 3,969
ayyy52.50 |
01-12-2017, 10:08 AM | #19 | |
77
Rep 330
01-13-2017, 09:05 AM | #20 |
59
Rep 457
My sub that I used to run in my E46 tourer
2016-08-21_04-23-24 by Phil Cookson, on Flickr 2016-08-31_10-51-46 by Phil Cookson, on Flickr 2016-09-11_08-28-36 by Phil Cookson, on Flickr 2016-09-11_08-28-25 by Phil Cookson, on Flickr I really need to get my arse in gear and install it into my E91. Hoping the boot is as wide |
01-13-2017, 10:14 AM | #21 |
Lame Stance Dude
53
Rep 204
Just four decent-length screws; can't remember the length. The panel is definitely pressed against the seats, but if I want a strong seal I can use some angle iron brackets and really shove that thing against it. But for now it sounds perfect!
01-15-2017, 11:17 AM | #22 |
16
Rep 80
Hi-Fi | AudioControl D6.1200 & Crescendo-S1V2 | FiQ 12" | Morel MSW 265 8" | Morel MSW 114 | Dayton AMT Tweeters
