BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Car died - No Start - (FIXED)
      12-11-2016, 09:43 PM   #1
TorqueAddict
TorqueAddict's Avatar
171
Drives: 340i - 335D
Hello guys,
Just posting this here so just in case if you face similar issue, you know what to do. So here is what happened:
Came home from gym, waiting for my wife in the car on the driveway and i suddenly see the red airbag sign go off on the LCD display, followed by the service light sign (RED sign, car on lift), and a yellow warning triangle, circling.
Steering controls stopped to work, odometer and tachometer died, all lights on the dashboard lit up - car was still idling. I shut down the engine, and tried to start it again - nope - no go.
Tried a few different things that night (the most common issues) - disconnected IBS cable, checked battery voltage checked fuses etc, everything seemed OK. Tired and cold went to bed. The next morning i fiddled with it again, and i held the brake and the starter button for like 30 seconds and car fired up, but still all the symptoms persisted.
I drove to my trusted mechanic and he was like yup, i exactly know whats wrong. He removed the glove box, and just below the FUSE box, there is a thing called "Fuse junction box body control module", he applied some dielectric grease, put everything back together and that was it, under 10 minutes everything was back to life.
Following are the pictures (taken from the internet)
Fuse box (without the module):
The module by itself:
You guys can figure out how it plugs in, so basically the contacts were cleaned and dielectric grease was applied to fix this.
Hope this helps.
EDIT: ...and my OBD port went dead as well, so i wasn't even able to scan for any codes.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
Appreciate 4
      12-11-2016, 10:53 PM   #2
JOHNNYBRAVO1
NY BRAVEST
47
Drives: 2010 Monaco blue, 335D
Great, thank you very for that heads up.
      12-12-2016, 04:51 AM   #3
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
Excellent thanks.
      12-12-2016, 05:22 AM   #4
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Son, this is a great topic. I appreciate your efforts and reciprocate with a sac lathering.
      12-12-2016, 09:06 AM   #5
TorqueAddict
171
Drives: 340i - 335D
Originally Posted by JOHNNYBRAVO1 View Post
I don't see any pics
Fixed.
      12-12-2016, 09:07 AM   #6
TorqueAddict
171
Drives: 340i - 335D
      12-12-2016, 10:31 AM   #7
lnxguy
357
Drives: 2009 335D
Glad you got it fixed man!
'09 335D
      12-12-2016, 10:49 AM   #8
TorqueAddict
171
Drives: 340i - 335D
Ya man, this was a weird one. And thanks for your response regarding my PM.
      12-12-2016, 11:11 AM   #9
Torqu3
321
Drives: 2011 335d
Usually you want to keep the Christmas lights away from your dash this time of year. Glad to hear it got fixed easily and quickly. Thanks for the heads up. Hopefully this isn't a normal issue.
      12-12-2016, 11:27 AM   #10
TorqueAddict
171
Drives: 340i - 335D
^ I hope so too. Apparently there was a recall regarding fuse box issues. I tried calling BMW Canada, and according to them my car (VIN) isn't a part of this recall. Please refer to the attached SIB's.
      12-12-2016, 11:50 AM   #11
Torqu3
321
Drives: 2011 335d
Good old BMW, throwing parts at a car that only required a little cleaning and dielectric grease. Hope it didn't cost you very much.
      12-12-2016, 06:43 PM   #12
TDIwyse
614
Drives: 2011 335d
OK... I don't know exactly what "sac lathering" means and what you northern guys do for entertainment, but that line, along with this one, caused me to choke on my beer.
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      12-12-2016, 09:51 PM   #13
GottaBeKD
GottaBeKD's Avatar
136
Drives: 335d
How's your golf game?
      12-16-2016, 09:07 PM   #14
335duff
25
Drives: 2011 335d E90
Any idea why? Early in my ownership I kicked my obd cable and broke the port off, it wasnt too bad to replace. Needed to buy a tool to remove the pins from the broken connector, and replace like 2 of the pins. Lube the steering shaft while you have all that shit apart.
      12-17-2016, 06:34 PM   #15
TorqueAddict
171
Drives: 340i - 335D
Because the power to the OBD routes through the fusebox, and that was where i had the issue.
Tags
airbag, fuse box, no power, no start, odometer
