2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB M240i brake fluid
      12-10-2016, 11:49 AM   #1
AlexM240i
102
Drives: M240i
Question M240i brake fluid
Hi.
I have 2 questions:
1. What's the DOT spec of the OEM brake fluid in BMW, particulary a 2017 M240i ?? DOT4 ? DOT 5 ? DOT 5.1?
2. Is it recommeded to change the OEM brake fluid for a Motul DOT 5.1 brake fluid like this ?
https://www.amazon.com/gp/product/B00CMZQMKS/
      12-10-2016, 04:44 PM   #2
Joe240
Joe240's Avatar
2925
Drives: 2021 C8 Corvette 1LT
I've. Even trying to figure this similar thing out. For normal street use, stock fluid is all you need, but if planning on tracking at all, then something higher temp is recommended. I'm assuming factory is DOT4.
The problem With the higher temp stuff is that it needs to be replaced more frequently because it absorbs more water, quicker. But from what I've been able to find, ATE Gold is one of the better ones that's not as bad with water absorption, not quite as high temp as the others though, but still higher than stock.
My question is, how much is needed to do a full flush?
AlexM240i101.50
      12-11-2016, 11:37 AM   #3
zipphreak
No_Country
454
Drives: m235xi
ATE 200 is good stuff. I like it, you should be fine with one can. But i would get two to be safe, especially if you are turkey basting the master cylinder to remove the old fluid.
I have used all sorts of full synthetic dot4 fluids. OEM, ATG Type 200, Valvoline, Johnsens.
The best/most expensive fluids, have a high temperature "wet" boiling point or approximately 3.7% moisture content (industry standard calculation for 2 years of service life), vs dry which is 0% (new in bottle).
Check out this fluid comparison chart thingy:
https://www.lelandwest.com/brake-flu...ow=1&SF=4&ST=2
fancy baster
https://www.amazon.com/Norpro-Deluxe...ter+automotive
fancy brake bluid
https://www.amazon.com/ATE-706202-Or.../dp/B003VXRPL0
Motul 600
https://www.amazon.com/Motul-8068HL-...ng+brake+fluid
Motul 660
https://www.amazon.com/Motul-847205-...ng+brake+fluid
Castrol SRF
https://www.amazon.com/Castrol-SRF-R...ng+brake+fluid
Johnsens's
https://www.amazon.com/Johnsens-5032...+4+brake+fluid
Appreciate 4
      12-12-2016, 01:45 PM   #4
mdputnam
mdputnam's Avatar
289
Drives: 135i & M235i Convertibles
I believe that that BMW recommends low viscosity brake fluid for the M235i/M240i due to the much higher frequency of electronic brake application required during stability control.
ATE's low viscosity fluid is SL.6
ATE SL.6 viscosity at -40C is 700 mm2/s
ATE Type 200 viscosity at -40C is 1,400 mm2/s
AlexM240i101.50
      12-12-2016, 03:50 PM   #5
zipphreak
No_Country
454
Drives: m235xi
Do you have a reference for that ? Where did you hear it from ?
edit:
AlexM240i101.50
      12-12-2016, 06:18 PM   #6
AlexM240i
102
Drives: M240i
edit:
Attachment 1540922
That said, it's better to stick with the OEM brake fluid...
The Motul DOT 5.1 has low viscosity ??
      12-12-2016, 06:31 PM   #7
AlexM240i
102
Drives: M240i
Thanks.
      12-14-2016, 12:53 PM   #8
mdputnam
mdputnam's Avatar
289
Motul DOT 5.1
Viscosity at -40°C 820 mm²/s
AlexM240i101.50
      12-14-2016, 01:09 PM   #9
AlexM240i
102
Drives: M240i
Motul DOT 5.1
So it's too thick...
      12-14-2016, 05:48 PM   #10
mdputnam
mdputnam's Avatar
289
Well, Motul DOT5.1 is only slightly thicker than ATE SL.6 or Pentosin Super DOT 5.1, but it is still significantly thinner than standard viscosity brake fluid.
AlexM240i101.50
      12-15-2016, 11:59 PM   #11
Maynard
3848
Drives: 228iX & M2C
Keep in mind that the water that is absorbed will then be working to corrode the internals of the brake system, so the track fluids that need to be changed twice as often have some additional liability for a long term driver. It can be a real PITA to keep up with all those changes, and many people get slack and just change them at the start of each season.
AlexM240i101.50
      12-16-2016, 10:29 AM   #12
mdputnam
mdputnam's Avatar
289
I use a Schwaben brake bleeder. It takes about 20 minutes with one of these handy devices:
Appreciate 2
AlexM240i101.50
Tpeterson156.50
      12-16-2016, 12:19 PM   #13
123Britt
289
Drives: 15 M235i AT
Nice Video
I have a Motive Power bleeder but have never filled the tank - only used it for pressure so it doesn't have to be cleaned. Takes more time for sure.
Also using the ATE TYP 200 fluid -- good fluid for an OEM replacement non track .
AlexM240i101.50
      03-20-2018, 10:11 PM   #14
ggggbmw
433
Drives: 2017 M2 Manual
Track Day Fluid? Usual choices are high viscosity.
I did a car control clinic last year, and the brakes were fading badly at the end of the day. This year I want to do some more ambitious HPDE and AutoX runs, and all the forum posts say to upgrade to a track oriented fluid.
Motul RBF 600 is a popular choice (but pricey), or maybe ATE 200.
But after reading this thread, I'm concerned about the viscosity of these fluids. the -40F rating for the Motul is 1750, and 1400 for the ATE 200. That's way over the ~700 of low viscosity fluids.
So, are there any high boiling point DOT4 fluids that are low viscosity? Looks like ATE SL.6 is a LV fluid, with better than OEM boiling temps. But it's a long way from the track oriented fluids. Anything better out there?
Or, does everyone just switch back to low viscosity fluids in the fall? (I live in Minnesota, so a -20F day is fairly normal. I'd like my ABS to work well in the snow/ice/cold.)
      03-21-2018, 07:41 PM   #15
pikcachu
pikcachu's Avatar
1400
Drives: M235i (F22 Red angel)
get the RBF 600 it's $18 per bottle... https://www.amazon.com/Motul-MTL1009.../dp/B004LEYJO4
the expensive is the Castrol SRF for $60 https://www.autohausaz.com/pn/CA-218...SABEgKUx_D_BwE
      03-21-2018, 08:42 PM   #16
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
anyone here try pentosin? My shop just put some in my 2 series.
dot4lv is the product. I think it was approx $ 12/quart
      03-22-2018, 11:24 PM   #17
ggggbmw
433
Yeah, definitely not going for the SRF. That's silly. That $18 a bottle for the RBF600 is only for 500ml though. I will need at least two bottles to flush, so ~$36. That's about 2.5x the price of a high-end street low-viscosity fluid, like ATE SL.6.
Still, my serious SCCA racing brother swears by the RBF 600. And it sure seems to be the popular choice on this forum. I'm resigned to spending the money on it.
My question though is still about using these very high-viscosity fluids in this car on a routine basis. The standard fluid is a low-viscosity to improve the action of the ABS and all the stability tweaks it is doing. I'm guessing that while the fluid is hot on a summer race day it's thin enough not to matter.
But, on a cold rainy day, when you really need the ABS and stability control, will these high-viscosity fluids reduce their effectiveness? And especially in the winter? Anyone notice issues with high-viscosity fluids in colder weather?
Do people flush back to stock low-viscosity fluids for the winter?
I know that high-temp fluids should be flushed annually anyway. Guess it isn't a big deal to say they have a six month life and go back to LV fluid for the winter. Would like to know what people do.
Related question. Nobody has referenced activating the ABS during a flush. Is it necessary? What if I'm going between high-temp and LV fluids? And how do you activate the ABS pumps if I want to?
      03-23-2018, 12:24 AM   #18
pikcachu
pikcachu's Avatar
1400
I just keep the fluid year around without issues
      04-05-2021, 06:05 PM   #19
AleksanderSuave
193
Drives: 2017 M240iX Coupe
necro-threading here but what is the total amount of brake fluid needed for the full bleed?
Cant find a legit source anywhere.
      04-05-2021, 07:39 PM   #20
bthomas518
62
Drives: 2016 228i
Are people tracking at -40C? Seems bold.
Anyone know viscosity of SL.6 vs. Typ200 at ambient and/or operating temps?
      04-07-2021, 07:22 PM   #21
ggggbmw
433
A simple flush takes about a liter.
If you run the ABS bleed procedure, it depends how quick you are opening/closing bleeders and running the process. At least 1.5 liters, and I usually use 2.
That's also why I only do the ABS cycle bleed in the fall when I'm putting cheaper Pentosin LV fluid in. Don't want to waste that precious Castrol SRF.
      04-07-2021, 11:20 PM   #22
AleksanderSuave
193
Thank you for the help. I ordered 2 liters of ate typ 200 just in case. What are you running the ABS bleed cycle with? I have an Autel maxi check pro that says it’s capable of doing so but never checked if it works with our cars.
Any chance you have the details on the procedure?
2addicts
