12-10-2016, 04:00 AM | #1 |
436
Rep 571
400bhp, do I need to upgrade intercooler?
Before I pull the plug, do I really need to upgrade the intercooler on my M2? I'm currently running about 400bhp and 435ft/lbs torque. Only real mod outwith the piggy back is the mpe.
On the dyno I was seeing Temps of 75 deg c between runs, recovery was quite quick but obviously real world is different and those temperatures will be different (less) . It's too cold and wet to get any good results regarding heat soak etc. now. I live in the UK so Temps are never that high, average summer is about 16 deg c. Don't want to upgrade if I don't need too but would welcome some input on this. Last edited by kiysersosae; 01-03-2017 at 03:04 AM.. |
12-10-2016, 06:08 AM | #2 |
3179
Rep 2,577
I heard from Dinan that a IC does have gains though minimal, at above 5K.
More importantly, cooler IAT helps hit target load easier, makes more consistent and reliable power. The only concern would be turbo lag introduction from a bigger IC. Tune/piggyback can make a sharper throttle response to make that lag less noticeable. But the fact the air has to fill up a bigger room before entering cylinders is a hard fact. I myself am on the fence on IC route, especially when not ready for big build.
Lemania 2320
12-10-2016, 07:56 AM | #3 | |
436
Rep 571
Its a tough decision. |
12-10-2016, 11:14 AM | #5 |
436
Rep 571
Stienbauer... Had it on the dyno at 398bhp 430 ft/lbs torque. I think it would have produced a bit more had it not been heat soaking. Ignition timing was being pulled to about 2 degrees, hopefully with the intercooler it will fix this, at least on the dyno. Still though, I'm not 100% sure on going for the intercooler.
12-10-2016, 11:23 AM | #6 | |
3179
Rep 2,577
Lemania 2320
12-10-2016, 11:41 AM | #7 | |
625
Rep 796
I've seen some IC's on this car actually drop IAT delta's through multiple gear pulls which could mean 30whp gains if the car is heat soaked. For sure worth it. |
12-10-2016, 12:07 PM | #8 | |
436
Rep 571
although the stock run was not accounted for as I thought the remote was set up and it wasn't, the piggyback was permanently switched on while in the dyno shop... My bad! Il get it in after Xmas to nail the stock and piggy back runs and see what delta we get. Last edited by kiysersosae; 01-03-2017 at 03:07 AM.. |
12-10-2016, 07:05 PM | #9 | ||
3179
Rep 2,577
I'd appreciate if you do these back to back: 1) Stock 2) Piggyback only as you are now 3) DP & IC on stock tune 4) DP & IC on piggyback Comparing #3 & #2 is meaningful, because I suspect stock car doesn't even hit stock tune load target at top end - this thing is desperate for timing if the significant power gain out of higher octane alone is any indication. The DP and IC helps turbo work easier with much less heat soak, which probably a stock tune would be taking good advantage of. My money would be on #3 beats #2 Looking forward to your results.
Lemania 2320
12-14-2016, 12:45 PM | #10 |
BimmerPost Supporting Vendor
24163
Rep 190,725
I would upgrade the intercooler, something like Wagner EVO 1 should be enough
12-14-2016, 01:09 PM | #11 |
96
Rep 185
Thing is, unless you are racing the thing, it doesn't really matter... On the street, your full throttle time is what, .01% of the run time? If you log it you'll be amazed how little you have it pegged which is the only time that the IC is going to matter. Its probably the last thing I'd upgrade unless it just makes you feel good. I put on a big EVO raceworks on my Audi when I strapped a big turbo on it (doubling the HP), but for the minimal gains the M2 gets via chip it hardly seems worth it. I added almost 100hp to my Bug without an IC upgrade, and it still pulls hard over in 100+ degrees in the Dallas heat all day long (street driving of course). Does it help? yes. Is it worth doing with just chip/dp for street driving at such minimal power increases? up to you, but probably not for most people. I'd only do it with a turbo upgrade myself, but YMMV.
12-14-2016, 03:00 PM | #12 | |
436
Rep 571
12-14-2016, 03:51 PM | #13 | |
96
Rep 185
12-14-2016, 05:07 PM | #14 | ||
3179
Rep 2,577
Lemania 2320
12-21-2016, 08:31 AM | #15 | |
1913
Rep 2,210
Drives: '17 jackrabbit on crystal meth
I'm at your power/tq levels. When I upgrade to stage 4, an IC will be going on as it's required.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
No Boost4021.00 |
12-21-2016, 04:07 PM | #16 |
436
Rep 571
auf Deutsch1913.00 |
01-02-2017, 10:27 AM | #17 |
3179
Rep 2,577
Any data log available to share with?
Lemania 2320
01-03-2017, 03:01 AM | #18 |
436
Rep 571
No, it was too cold and slippy to get any strong consistent pulls, I'll need to wait until March I think. What I did notice was the temperature outside was around 4deg c and sitting at 70mph on the motorway the Temps were around 19deg C which I thought was high. Last edited by kiysersosae; 01-03-2017 at 03:10 AM.. |
