Glow plug removal question
12-09-2016, 02:14 PM | #1 |
Master and Commander
17
Rep 55
While I have the intake manifold off my car for CBU purposes I was going to replace the glow plugs and glow plug controller. I was getting a couple of glow plug errors but they did not point to a specific cylinder. Probably means the controller is the issue.
Anyway, I went to remove the 1st glow plug and it seems to be super tight. I am now paranoid of breaking it trying to get it out. I sprayed them all with penetrating oil around the base and I am letting them sit for awhile. Question: If I turn the ignition on will the glow plugs go to preheating mode? I understand that heat and penetrating oil may help, but I do not want to put a torch there. Any ideas on what is the best way to heat them up is? Thanks! PS - it is cold in Atlanta today low 26 hi 42. |
12-09-2016, 03:01 PM | #2 | |
89
Rep 183
I believe you can start the engine without the manifold and let it idle for a while and then try removing them. |
12-09-2016, 09:03 PM | #3 |
277
Rep 1,575
Yes. I believe it says it in bold to have the engine up to operating temperature because you can damage the threads. I can't say anything about running the engine with manifold off.
