12-09-2016, 08:43 AM | #1 |
81
Rep 427
Torque Steer ?
Had my winter tyres re-fitted this week. (Wintract Extreme).
One was damaged so replaced it with a brand new one. The others have approx 5mm tread left. Now found when accelerating hard, I have to gradually steer left until I change gear. I had the new tyre fitted on the rear (thinking more tread, better traction in snow etc), but now think that was a mistake. Anyone experienced similar?
F30 Estoril Blue 335D MSport.
12-09-2016, 09:02 AM | #3 |
1867
Rep 13,043
Drives: BMW M340I G20
Are you confusing tramlining with TS?
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
12-09-2016, 09:30 AM | #4 |
81
Rep 427
Rather unconventional use of the phrase ‘torque steer’, I know….
But the car ‘veers’ to the left during hard acceleration. I’m suspecting the diff is tightening under high torque conditions and the larger diameter wheel is causing that side of the car to be slightly faster. Hence my phrase ‘Torque Steer’ The diff should look after the difference but there’s probably a limit to everything. I’ve expereienced tramlining before and its not that. I’ll get the wheel with the new tyre swapped with a front at the weekend and try again.
12-09-2016, 09:44 AM | #5 |
1983
Rep 3,216
Personally, I'd have changed the pair of tyres on the back, so that they had equal tread depth. I've always felt that having different tread depths on the driven axle leads to component wear.
Not sure what BMW say about it these days, but pretty sure they used to say to swap as pairs. |
12-09-2016, 10:37 AM | #7 |
409
Rep 1,162
With uneven traction from side to side it is possible to induce what feels very like conventional torque steer in an xdrive. I've encountered this numerous times on wet and greasy surfaces. However on the same road when its dry performing the same manoeuvre there is no detrimental feedback through the steering.
In a rear wheel drive car the rear end would twitch/slide about in the same circumstances. |
12-09-2016, 03:01 PM | #10 |
81
Rep 427
I'll check the tyre pressures first thing tomorrow.
As for the Banana, i've got a bunch of them to choose from and just picked the biggest The tyre place also did a 'free' wheel alignment, which didn't go well. I hope its nothing to do with that...
12-09-2016, 04:05 PM | #11 |
177
Rep 365
Also just to add, check the tyre has been fitted the right way round. Also grip level on the new tyre will be lower for the first few hundred miles or so.
12-09-2016, 04:05 PM | #12 | |
6659
Rep 15,858
BTW, it won't be the diff limiting the straight line feel. If it is tyres, more likely the difference in grip levels. Remember cold weather tyres do need a few miles to get to full grip. |
12-09-2016, 07:51 PM | #14 |
10995
Rep 32,881
If tyre pressures don't sort it then it is almost definitely the wheel alignment! Take it somewhere with a Hunter wheel alignment machine, they usually do a free check.
12-09-2016, 11:37 PM | #15 |
4372
Rep 4,230
Think you've answered your own question there...
....,,,,..,,..6734.00 |
12-10-2016, 04:46 AM | #16 |
288
Rep 1,201
the xdrive does give a torque steer feeling I have noticed. but it is actually following cambers and rivets in the road. made worse under acceleration on uneven surfaces. I know this doesn't answer your problem as it's mostly un noticeable so.
12-10-2016, 08:10 AM | #17 |
2812
Rep 4,935
Drives: 340i MPPSK
Used to own a Renault 5 GT Turbo.... now that had torque steer!
Life is a state of mind |
12-10-2016, 10:04 AM | #18 |
81
Rep 427
Tyre pressures were ok.
Swapping the wheels front to back has fixed it. Whether it was the larger diameter of the new tyre or lower grip, I'll never know. But I won't be doing that again... Now. Where's that bunch of bananas gone?
12-11-2016, 05:32 AM | #19 |
14
Rep 42
