recommended products for novice detailing
12-08-2016, 05:44 PM | #1 |
169
Rep 1,039
Which are the best and easy to use products to do a minor to moderate swirl problem on a black car?
Then will top with cquartz uk. I've read 3m and menzerna are great. Looking to buy the porter DA. |
12-09-2016, 07:28 AM | #2 |
360
Rep 5,052
Hi,
Hopefully I can help by providing some recommendations based on my own experiences with black BMW's... is your vehicle BSM or Jet Black? I would highly recommend the Griot's Garage BOSS Line Up. We have found this system to work extremely well in almost every case. Compound & Polish Griot’s Garage Fast Correcting Cream – Our favorite cutting compound that provides a long working time, relatively easy wiping, and great cutting power to remove heavier swirls and moderate scratches. Works great on Microfiber pads as well as foam pads. Griot's Garage Correcting Cream - A fantastic medium polish that is great for "one-step" paint corrections. Capable of removing moderate swirl marks and producing an exceptionally glossy finish. Long working time, low dust, great scent. Griot's Garage Perfecting Cream - A fine finishing polish that will help to produce great clarity and gloss. Long working time, low dust. Pads Microfiber Pads - Most aggressive. Perfect for heavier cutting when you need to level the paint quickly, or if you have harder paint to begin with. Fast Correcting Foam Pads - a stiff, firm foam pad that works great for cutting while producing a rather nice finish for the degree of defect removal that you can achieve. Correcting Foam Pads - A medium cutting pad that works great for removing moderate swirl marks and defects. Perfecting Foam Pads - A softer pad that is great for final polishing. Finishing Foam Pad - A very soft pad that can be used for final polishing on exceptionally delicate paint or for spreading your favorite wax or sealant (if you're not applying a coating) **Griot's Garage Foam Pad Kit** - This kit includes 2 of each of the foam pads and when ordered as a kit, there is a discount already applied! **Griot's Garage 6" Polisher & Pads Starter Kit** - This kit contains the awesome Griot's DA polisher and 2 of each of the most important foam pads (fast correcting, correcting, and perfecting). This kit is also discounted compared to purchasing each item individually. Griot's Correcting Cream + Correcting Pads made easy work cleaning up the mild swirls on this 335i. Here is a before/after shot of the same hood that was restored with Griot's Correcting Cream and Correcting Pads. Heavier defects were present on the sides of the vehicle... These were leveled with Griot's Fast Correcting Cream (FCC) & Microfiber Cutting Pads The areas that were compounded with the FCC were later followed up with a fine finishing polish before being coated with 22ple. As far as the polisher goes, you had mentioned the PC7424XP, which is a great little machine, but I would highly recommend spending a little bit more and getting the Griot's Garage DA Polisher. The Griot's Machine is very similar to the Porter Cable in terms of size and appearance, but it has a slightly more powerful motor which will help you to accomplish your work quicker, and most importantly it is backed by an outstanding lifetime warranty against any manufacuterer defects. So if anything ever goes wrong as the result of the original parts (ie not user abuse/misuse) then the unit should be repaired or replaced by Griot's free of charge. You really can't bea that! You may find these other articles helpful as well... Two-Step Paint Correction Overview (see video inside) Analyzing Your Test Spot Pairing Products and Pads Polishing Pads - How Many Do I Need? Let me know if you have any other questions! -Zach Last edited by Detailed Image; 12-09-2016 at 07:33 AM.. |
12-09-2016, 08:41 AM | #4 |
74
Rep 322
In terms of product though you can't go wrong with the Boss line of polishes, they are really forgiving and you can work them seemingly forever....Menzerna makes great products as well, ....specific to Menzerna products I have had good luck with on my SGM 335i with MC2500 paired with LC Orange pads, knocks out minor imperfections with ease and leave a great finish......or if you prefer a more correct/protect or 1 step solution I have also had success with Menzerna 3in1 on LC Orange (my got to for one step detailing).
I also agree with Zach, the GG6 is the way to go .....
MHD Stage 1+ FMIC // VRSF 5" stepped// StopTech x-drilled Centric Posi-Quiet Ceramic Pads // Wiesslicht AE's // OEM Blacklines // Matte Kidneys // MonoChrome emblems.....
12-09-2016, 08:55 AM | #5 | |
360
Rep 5,052
I personally do not use Menzerna much anymore, but I have in the past and had fantastic results with their products. Definitely a great option. Menzerna Line Up Heavy Cut Medium Cut Super Finish *note there are other Menzerna abrasives as well for heavier cutting and finer finishing* |
12-09-2016, 09:40 AM | #7 | |
360
Rep 5,052
The reason I had asked whether your BMW was BSM or Jet Black is because BMW paint can vary greatly in terms of hardness. BSM is quite hard and jet black is much softer. Long working time means you can make many passes without the product drying up and dusting. Products with a shorter working cycle are typically more frustrating for beginners to use. -Zach |
12-15-2016, 04:42 PM | #8 |
68
Rep 1,324
Once the paint is polished, don't forget to pick up some Blackfire Wet Diamond to seal the paint. I love this stuff, and today (12/15/16) it's on sale for about 40% off and no-minimum free shipping! I recommend this stuff when it's full price, and if I didn't have a mostly-full bottle at home I'd be buying a spare. Seriously, it's awesome.
And pick up some Waffle Weave towels for drying, while you're at it
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
12-16-2016, 09:40 AM | #9 |
428
Rep 707
12-22-2016, 09:57 PM | #10 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
Zach,
can you replace 6" backing plate to 3" on **Griot's Garage 6" Polisher ? |
12-23-2016, 08:51 AM | #11 | |
360
Rep 5,052
Backing Plates from DI 6" Backing Plate 5" Backing Plate 4" Backing Plate 3" Backing Plate | Griot's Option This is one of the reasons I recommend this machine to DIYers instead of the professional grade machines that do not have interchangeable backing plates. It makes much more sense for users to have one machine that does it all rather than have to spend a lot more money on 2-3 machines when you only use them a few times a year at most. -Zach |
12-23-2016, 09:17 AM | #12 |
602
Rep 2,703
Thanks Zach,
do they provide wrench with this polisher to change backing plates? |
12-23-2016, 01:20 PM | #13 | |
360
Rep 5,052
Flat Wrench for DA Backing Plate |
12-25-2016, 09:21 PM | #14 | |
Rep 19
12-26-2016, 08:35 PM | #15 |
360
Rep 5,052
01-03-2017, 07:39 PM | #17 | |
360
Rep 5,052
Pads Backing Plates -Zach |
