Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > water methanol controller
      12-07-2016, 04:43 AM   #1
32valves
32valves's Avatar
109
Drives: 2011 335d sport
does any know who sells a water/ meth controller that uses a boost reference instead of a maf signal?
      12-07-2016, 07:19 AM   #2
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
375
Drives: Deezul
AEM does with their universal diesel controller.
Deleted, ATM I/C and tuned by B.R.R.
      12-07-2016, 08:18 AM   #3
Venom107
22
Drives: 2011 335d
Devil's Own uses boost.
      12-07-2016, 08:20 AM   #4
32valves
32valves's Avatar
109
I looked at their DVC 30, it's an option.
That's the brand I'm running just with there mechanical boost switch.
      12-07-2016, 08:59 AM   #5
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
I really like the torqbyte controller so far. Boost and rpm. It can be operated just boost if you'd like as well.
      12-07-2016, 10:41 AM   #6
Venom107
22
Drives: 2011 335d
I Have the DVC 30, wish I had the DVC 100 or another controller. Running 1000cc starting at about 24lbs boost and its all in at 30. I would like a little more adjustment for my current and future boost levels.
      12-07-2016, 02:19 PM   #7
natefank
Drives: 335d
I'm using snowperformance mpg max controller and love it, super easy to set. U can use either boost or EGTs for the meth
      12-07-2016, 03:09 PM   #8
32valves
32valves's Avatar
109
controller
there is a dvc 100 now?
      07-03-2017, 07:54 AM   #9
32valves
32valves's Avatar
109
Ok I just ordered the devils own dvc-100.
Trying to tweek the car before bimmerfest east at the end of the month.
      07-03-2017, 08:49 AM   #10
335dsleeper
389
Drives: 09' 335d 10'35D
Have you looked at torqubyte? Its like 299 and is a much better controller.
      07-03-2017, 08:58 AM   #11
32valves
32valves's Avatar
109
Know I forgot about that one, but it's seems a bit overkill for my single nozzle.
But it looks to be the best on the market I see.
      07-03-2017, 09:37 AM   #12
racediesel
Drives: BMW 535xd 2012 F11
https://www.wengineering.de/
      07-03-2017, 10:00 AM   #13
335dsleeper
389
It's not overkill at all.
      07-03-2017, 07:01 PM   #14
WreckerX5d
Warrant Officer
WreckerX5d's Avatar
375
Drives: Deezul
I use the Toquebyte and I find it not overkill at all.
      07-04-2017, 12:19 PM   #15
335dlci
277
Drives: 335d
Also use TB. Love the product.
      07-05-2017, 08:26 PM   #16
Asonchadwick
Sleepy
75
Drives: bmw
I can tell how i did mine. I bought a nitrous oxide controller from NOS. It has a user programable interface on the computer and you can use boost, rpm, tps and a few other parameters. I just used boost. I like it because i can make my own curves but you would have to tie into all the sensors which i dont like but thats completely normal. Also it has 2 channels so you can run one pump and two solenoids or 2 pumps. Also it can change the pwm frequency in hz from 15 to 60hz which could be handy for fine tuning. So i just ran mine real simple in my vw and on one really large nozzle i could quench the combustion if i wanted but other than that i can run a really large nozzle and tune it so it isnt overkill and just have as big a nozzle as i will ever need. This pulses the pump as they can be pwm but i had plans to pulse a solenoid and run the pump full psi. Another advantage of this controller is it has additional triggers so you can trigger the pump on 100% when activated and it will pulse the solenoid(s) at whatever duty cycle and frequency you want just like a fuel injector. The only thing is the only one company i could find has solenoids capable of such a setup and that's wizards of nos. Their pulsoids are good for 1,000,000 or so cycles and can handle varying frquencies and pressures. 250 psi will be no problem for them at all. So i set mine up super simple for proof of concept and it worked perfectly. Run one channel for w/m and the other for nitrous hehe.
      07-06-2017, 03:05 PM   #17
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
^Another good idea thanks for sharing. I thought about that once but didn't pursue.
My torqbyte controller is still rock solid, without one hiccup. The torqview Bluetooth device is awesome as well, plug and play. I'm starting injection at 26psi/2300rpm, I did lower before but find this more optimal.
Firmware updates and customer service is top notch! Their LPFP controllers look appetizing for our ds as well, hmm...
      09-24-2017, 12:47 PM   #18
335dsleeper
389
Is anyone using solenoid with the torqbyte controller?
      09-24-2017, 06:11 PM   #19
Andy198712
145
Drives: 2010 E91 325d
Can I ask how you are finding the change from boost switch to a digital controller?
      09-24-2017, 08:27 PM   #20
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
No. Originally I was, but the snow nozzle check valves work great along with another check upstream.
You run the wiring I believe to gpo1 and then adjust over the software. I guess the main advantage would be to pre prime the pump before the nozzles spray.
I love it. The mechanical boost switch can be somewhat unpredictable and can build boost too early causing quench.
The torquebyte controller is completely programmable. I'm comfortable leaving it on all the time now driving with no issues. Once you dial it all in perfectly you'll be happy.
      09-26-2017, 08:21 AM   #21
DWR
798
Drives: 2009 335d
All of this feedback is great. Anyone have data to support their claims of getting a good tune? Rpm versus Boost should be a decent start for a map. What EGTs are you targeting? Same with AFR. With all due respect, anyone just using boost is leaving a lot on the table. This is a situation of compromise, as no one has produced a commercial system that controls AFR and EGT independently. Finally, large nozzles with PWM of the pump have inferior atomization, which creates unbalanced distribution. Yes, for some folks, I am being nit picky. Guilty as charged, no harm intended.
I guess my point is that you have to decide what and how you want to control before you can decide on a controller. IMO, you need at least rpm and boost as inputs, in order to create a decent map for open loop control. If you want any level of closed loop control, you need EGT, or EGT and AFR. I am not aware of anyone marketing a closed loop WMI system, but that just indicates how crude these things are. What is interesting is some of the available controllers could actual perform closed loop operation for this application.
      10-01-2017, 06:09 PM   #22
335dsleeper
389
Where did you pull RPM from?
