2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning B58 engine coolant
      12-05-2016, 09:29 PM   #1
AlexM240i
102
Drives: M240i
B58 engine coolant
Simple question:
Can i use the regular blue BMW coolant in the M240i to refill between service???
This one:
      12-06-2016, 12:39 PM   #2
amw896
amw896's Avatar
583
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
yea, you could but why would you need to refill? If your levels are dropping, get it checked out asap!!! Some guy in the 235 forums drove on a tuned n55 that required coolant refills. Turned out his head was cracked and he needed a new motor.
      12-06-2016, 05:28 PM   #3
AlexM240i
102
Drives: M240i
I normally do minor refills between services, like 10ml each month or so...
      12-06-2016, 06:49 PM   #4
amw896
amw896's Avatar
583
ahhhh fair enough....I thought you might be drinking a lot
      12-08-2016, 11:03 AM   #5
AlexM240i
102
Drives: M240i
      12-28-2016, 03:37 PM   #6
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
You should be able to go the entire 100,000 mile interval without having to add. If you do need to add make sure you dilute the coolant, its not designed to go in the system at its full concentration.
      12-28-2016, 05:55 PM   #7
XutvJet
5551
Drives: 2011 Cayman Base, 2016 M235
It's very common to lose a little water from the coolant over time due to evaporation. Yes, the system is technically sealed, but some water can be lost through reservoir cap. The coolant isn't disappearing, but rather it's water base. Every car I've owned has required around 150-200ml of top off every year. I've never owned a car that had headgasket issues of coolant leaks.
I did notice that my M235's coolant reservoir was slightly below the cold level when I got the car (new). I added 150ml of distilled water to bring it up to the cold level on a cold engine. Even under hard driving, the coolant level on the reservoir has never gotten more than midway between the cold and hot marks.
AlexM240i101.50
      12-28-2016, 08:56 PM   #8
AlexM240i
102
Drives: M240i
Yes. That's why i bought the BMW Coolant. Because of my OCD, i can't live with that reservoir with the coolant under de max line.
When i received the car the coolant level was also in MIN so i complete it. Why is that ?? In a new car with 5 miles when delivered ?
      12-28-2016, 10:32 PM   #9
XutvJet
5551
Keep in mind that coolant expands as it heats up. When the motor is stone cold, the coolant level should be at the minimum/low level. You don't want the coolant level at the max level when the motor is stone cold.
Appreciate 2
harma24402.50
amw896582.50
      12-29-2016, 08:04 AM   #10
AlexM240i
102
Drives: M240i
So i've been doing it wrong....
harma24402.50
      01-23-2017, 06:44 PM   #11
fiehlsport
50
Drives: '13 X1 xDrive35i
Why not just have the dealer top it off every time you take it in? If the car is legitimately losing coolant between services, they would be apt to top it off each time. Doesn't seem worth buying a gallon when the car is still within its free service period.
Plus, then you would have it on record @ the dealer that the car sips coolant in case there is ever a leak or coolant consumption issue out of warranty.
      01-27-2017, 08:52 AM   #12
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
there's a discussion going on the f3x forums as well.
http://f30.bimmerpost.com/forums/sho....php?t=1343545
2addicts
