M2 Technical Topics > Suspension | Brakes | Chassis > Softest lowering springs/coilovers
      12-05-2016, 04:27 AM   #1
Dave-A
Serial Car Buyer
Dave-A's Avatar
Australia
85
Drives: E82 1 Series M and E90 M3
I'm looking to lower my car .8-1". As this is now my daily, I'd like to retain as much of the factory ride as possible- the roads in Sydney are mediocre at best. I love the factory ride, but acknowledge that it's probably over damped and under sprung. What you, your mate or his dog run on their track cars is probably not helpful- I want to retain some comfort.
Not much is available here given the lack of good shops and taxes. The options seem to be:
KW V3
KW HAS
Eibach springs
I'm concerned that the V3s and HAS will be overly sprung and the car will be more unsettled on mid corner bumps, which leaves the Eibachs. Thoughts?
Is there another way to get the height?
Current: '12 E82 1 Series M and '09 E90 M3
Past: '16 F87 M2, '09 987 Cayman, '08 B7 RS4 Avant, '08 E92 M3, '01 B5 RS4 Avant, '05 987 Boxster S, '03 E46 M3, '04 Evo 8MR, and '01 8L S3.
      12-07-2016, 10:00 AM   #2
slashrawr
slashrawr's Avatar
Australia
95
Drives: Passat R36
I've had nothing but great results from Eibach Pro Kit springs in my previous cars so while I can't speak for their application on the M2, I wouldn't hesitate to run them myself on my M2.
      12-07-2016, 10:43 AM   #3
HP Autosport
BimmerPost Supporting Vendor
3843
Drives: F80 M3
Any of the H&R or Eibach lowering springs are very soft and progressive. KW V series will be the softer coilovers.
      12-26-2016, 12:41 AM   #4
Justin.AutoTalent
3138
Drives: F80 M3
The softest products will be:
- Springs: Eibach
- Coil overs: Bilstein PSS10 or Ohlins R&T
      02-15-2017, 10:26 PM   #5
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Won't m performance softest setting do it?
Lemania 2320
      02-15-2017, 10:57 PM   #6
Wangspeed
51
Drives: BMW M2
- Springs: Eibach
The rear springs on the Ohlins R&T are over 1300 lbs/in. I would not call that soft. There are multiple complaints about the stiffness. Mostly on the M3/4 board.
      02-16-2017, 10:43 AM   #7
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
you will be happy with the eibach product.
Tag18143.00
      02-16-2017, 11:40 AM   #8
BruceM
985
Drives: '17 6MT MG M2,930,Jag XKR 5.0
I'm on Eibachs. I like them. Feel a bit more connected to the road through the wheel, and ride is still just fine...
D CHOI581.00
      02-16-2017, 01:26 PM   #9
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
Yup I'll be going with Eibachs too as it seems to be the most popular set up.
      02-17-2017, 01:47 AM   #10
Dave-A
Serial Car Buyer
Dave-A's Avatar
Australia
85
All- I went with a KW HAS kit. Spring rates are the softest I could find.
I think the M2 suspension is slightly flawed- it is oversprung and under dampened- particularly noticeable on a choppy high speed corner. Where good dampeners let the car track well, the M2 skips. Perhaps a bigger sidewall would solve it?
I managed to do a back to back with my 987 and the better dampening is immediately noticeable.
Net result- don't lower- go coilovers instead.
      02-17-2017, 04:06 AM   #11
Yellowflash21
Slovenia
370
Drives: M2
Sorry, so what you meant to say is that HAS kit is even softer compared with stock springs?
      02-21-2017, 07:52 AM   #12
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
I can say the Ohlins will not be as soft as stock, even at the softest setting. What I can say is that the all-around ride will be much more solid. At least I can say this for my 335is. I just want back to stock shocks/springs from Ohlins. Feels like I am riding my my Ford Explorer now. Even will all of the M parts still on.
I don't think any of the kits mentioned will give you a softer ride. Don't know anything about Eibach springs, feel they would kill some handling performance.
BMW CCA and PCA HPDE Instructor
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022
      02-21-2017, 12:52 PM   #13
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
KW V3
KW HAS
Eibach springs
Apparently the Dinan kit is softer than stock. Not sure about the rates but the feedback is that it does indeed ride better. My H&R springs ride like stock for the most part. It's really going to come down to dampening
      04-03-2017, 10:19 PM   #14
Thespaz18
Thespaz18's Avatar
75
Drives: 2018 M3
I'm in the same position as the OP. Looking for a bit of a softer ride than stock. Matt Farrah's review of the Dinan M2 seemed to reinforce the Dinan suspension as being softer than stock. I'll have to do a bit more research. Anyone running the Dinan suspension on their M2?
      04-04-2017, 09:15 AM   #15
Dave-A
Serial Car Buyer
Dave-A's Avatar
Australia
85
The Dinan stuff sounds like a great option- especially if the dampening can be tuned/shimmed to ramp up at the end.
      05-07-2017, 07:56 PM   #16
Chaslieb
14
Drives: 2017 LBB M2
I'm bumping this to see if anyone will chime in on the Dinan HAS
VegasM285.50
      05-07-2017, 09:35 PM   #17
HP Autosport
3843
Drives: F80 M3
Correct. Unless softer springs are used in their place.
      05-15-2017, 01:11 PM   #18
ryem3
ryem3's Avatar
1042
Drives: 2020 MB M2 CS
The joke is that the Dinan suspension is adjustable springs only! How can stiffer springs with stock shocks be more comfortable than stock?
      05-19-2017, 08:19 PM   #19
Chaslieb
14
Drives: 2017 LBB M2
Anyone actually have the Dinan "coilover" kit?
Seems many opinions but not enough reviews. As things stand now, it seems the M performance coilovers are stiffer than the standard suspension, even when dialed down to soft. The other options are Ohlins which can be set up with softer springs than their engineers recommend if you want a street setup, or the Dinan spring "coilover" kit which only Matt Farah has said anything about to the extent that it is a more comfortable and livable setup even with a higher spring rate.
Looking to see if someone who actually has the Dinan setup wants to chime in on the street performance, especially on broken or bumpy roads, as compared to the stock springs.
      05-23-2017, 10:17 AM   #20
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I just installed the H&R springs and I would definitely say that the ride quality is pretty comparable to OEM. The lower ride height definitely keep the car flatter around corners. I have only put about 40 miles on the car since I installed them last weekend but I am really happy with the stance and the ride. Definitely a great option.
      05-23-2017, 04:58 PM   #21
Chaslieb
14
Drives: 2017 LBB M2
Do you find the M-Performance coilover to be better for daily driving duties?
As you have added these to your car, do you find the ride to be better over broken or bumpy roads? Have you adjusted both rebound and compression or just rebound on your car when changing the settings? How would you compare the ride to the stock suspension, and the change of ride once the damper settings were softened for off track purposes?
      07-17-2018, 10:30 PM   #22
TProfit
TProfit's Avatar
82
Drives: 2020 BMW M2 competition
Bumping an old thread but ... doesn't seem that a resolution was made.
What option would you go with for:
1)Softest ride/comfort
2)Stance (nice drop)
3)Handling
But what I'd reallywant is this:
https://f87.bimmerpost.com/forums/sh....php?t=1478200
2020 M2 Competition/ LBB/ DCT/ Moonroof/ Exec
Instagram - TProfit
m2
