12-01-2016, 08:42 PM | #1 |
BimmerPost Supporting Vendor
1997
Rep 6,916
Eventuri Carbon Fiber Engine Cover for the BMW M2 F87
I picked this up from the team at IND not sure if it's on the site yet but I believe they have them in stock. Everyone can use more carbon fiber..... Items that you will need - BMW Logo - part # 11 14 7 788 967 (this is not the same part number on our BMW M2 Engine cover) You will also need to pull the rubber grommets (total 3) out of the oem engine cover and put them into the carbon fiber cover as well as the insulation. Pics below. Since I'm a bit ocd I went ahead and used the Rupes Ibrid Short Neck with the Rupes Yellow Pad and Jeffscar Micro Finishing Polish (coming soon) to remove some of the hazing left behind from possibly the wetsanding and compounding after the clear coat was sprayed. I went ahead and polished it out to remove the haze and bring out the shine. Following it with 2 layers of Nanolex SI3D HD ; ) Haze on the CF Engine Cover Polishing the haze out I opted to remove the Eventuri decal..... Probably should have removed them first before polishing BMW Roundel Emblem Used Nanolex EX to prep the CF Engine Cover for Nanolex SI3D HD A nice thick coat of Nanolex SI3D HD goes on After Swapping out the grommets and insulation from the OEM Engine Cover OEM Engine Cover Back of Engine Cover with Rubber Grommets and Insulation Pulling out the insulation from OEM Cover Back of the CF Cover Installed rubber grommets Without insulation Before with OEM Engine Cover Eventuri Carbon Fiber Engine Cover Last edited by Detailers Domain; 12-01-2016 at 09:09 PM.. |
12-02-2016, 07:26 AM | #3 |
966
Rep 13,780
Phil, The dedication to perfection is inspiring. Thank you for showing the community your art and that its more then just business propaganda.
12-04-2016, 10:21 AM | #7 |
2274
Rep 2,523
Wondering if you can match the carbon Kevlar shades of the intake
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
12-05-2016, 02:50 PM | #10 |
24188
Rep 190,798
Looks great
Tags |
bmw m2, carbon fiber, engine cover, eventuri, f87 |
