11-27-2016, 06:54 PM | #1 |
33
Rep 92
Tire Rotation
Basic question, but I can't find it anywhere with the search. Does BMW rotate tires for free even when it would not fall under a service time? I usually rotate my tires every 5k, and I'm almost there. So before I go pay for this somewhere else I'd like to take advantage of the BMW service if it's available.
11-27-2016, 10:57 PM | #2 | |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
11-28-2016, 10:43 AM | #3 | |
Curmudgeon and Pedant
690
Rep 3,489
You have an MSport - doesn't it come with staggered tires/wheels? Can't rotate them anyway. |
11-28-2016, 10:55 AM | #4 |
481
Rep 1,572
I doubt you will find a dealership that will rotate tires for free without a specific maintenance/warranty reason. Otherwise, they can not charge it back to BMWUSA
Page 270 of my 2013 335i owner's manual states: "Rotating wheels between axles The manufacturer of your vehicle advises against swapping wheels between the front and rear axles. This can impair the handling characteristics." I think the reason is primarily due to the unique contact patterns between the front and rear suspension geometry that the tire adapts to that if swapped may impact the handling of the suspension. in reality, most of us would probably not notice any handling difference, but i suspect it would be noticeable on a good road course, at least, until the tires adjusted to the new contact pattern. |
dberry0832.50 |
12-04-2016, 01:04 PM | #6 |
40
Rep 125
Drives: 2013 328I Sportline
I followed the manual on my first set of tires and the rear tires wore out way before the fronts. On my new set, i have been rotating them every 5000miles. They are wearing much better of course and i dont notice any difference in handling or ride comfort. This will allow me to change all four when they are worn. I hate changing just 2 tires and also hate chnaging tires that arent worm out.
sspade2464.50 |
