FLA retrofit problem
11-27-2016, 08:35 AM | #1 |
50
Rep 63
Hi guys,
some days ago i retrofitet a mirror with FLA to my 2011 E92. What i did was: -wire it up -added $5AC to vo (CAS and NFRM) -coded FLA, NFRM, KOMBI, CAS and CIC with empty MAN So i thought everything is working fine and gave it a test drive, so i pushed stalk one time and in KOMBI the little new symbol for FLA came up, but it never activated high beam no matter how fast i was driving or how dark it was... So i tried checking FLA with INPA, but when i'm trying to go into the module it says: Translated it's someting like: "Searching for FLA_65, not found. Found instead: FLA_R. Action canceled" So i read UIF and it shows: Adr Name JobStatus SGBD ZB-Nr. ----------------------------------------------- 5F FLA OKAY FLA_R 9213316 When coding FLA with NCS Expert it always shows FLA_E65 stuff: Can someone please tell me what is wrong here? Why Inpa and NCS want to use FLA_E65 and not FLA_R? greetings jeezz Last edited by jeezz; 11-27-2016 at 12:17 PM.. |
11-27-2016, 12:51 PM | #2 | |
Ballin' out of control.
520
Rep 1,289
The INPA script FLA_65.IPO (V5.004) is telling you that it performed a module variant check and your FLA module is not a supported variant. FLA_65.IPO V6.xxx supports the FLA_R variant. INPA for F-Series contains the newer script that you need to access your FLA module. PM shawnsheridan, he can provide you with a download link. When default coding modules with NCS-Expert, always use the expert mode profile and run the SG_CODIEREN job. Using a blank man file can lead to unpredictable results. INPA and NCS-Expert make reference to FLA_E65 because it is the SGBD (Steuergeräte Beschreibungsdatei) that they use to communicate with the FLA module. If I was able to help you, please click on the Appreciate button below. It's greyed out until you hover your mouse over it...
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
11-27-2016, 02:01 PM | #4 |
50
Rep 63
Hey thank you guys!
808AWD325xi you were right, with the F-series INPA i was able to connect to my FLA, still getting some strange "api" errors when i want to watch the live data, gonna have to check that out next days Dtype also if it's a used FLA? greetings |
11-27-2016, 03:20 PM | #5 |
242
Rep 1,354
Actually that is not necessary.
You are better off "resetting" the FLA module to it's defaults after VO coding the car. You should also reset any modules that are associated with FLA functions including FRM, Kombi, RLS. CIC, CCC, etc. After the reset you should code Kombi to enable the appearance of the FLA icon and behaviour on the instruments. Have you also removed "Variable light distribution" from your VO, if you had it? |
12-02-2016, 04:32 PM | #7 | |
242
Rep 1,354
Excellent! Re: Variable That is a good thing! Re: Reset Do you see the "Auto" icon appear on your instrument panel when you have the automatic high beams on? Do you see a new entry in the NBT/CIC under light settings to enable or disable the FLA? If not you still need to reset the modules to their defaults so this appears after VO coding the car. There is also an option for the CCC to enable FLA sensitivity via the stalk, but I had to code my car to turn that on. Last edited by opjose; 12-02-2016 at 04:39 PM.. |
12-05-2016, 09:20 PM | #9 |
1495
Rep 3,148
I retrofitted an FLA mirror from a BMW 7 series (really old one) and behaved funny until I flashed it with WinKFP. Works perfectly now
See here http://www.1addicts.com/forums/showthread.php?t=1134963
