TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Issues after injector swap
      11-26-2016, 06:09 PM   #1
natefank
Drives: 335d
So I just got done replacing my injectors. Now I'm having studdering at 2500-3000 RPMs and have codes for "Charge Air Cooler Temperature Sensor Circuit High" and "Turbocharger/Supercharger "A" Underboost Condition" Anyone have any solutions? Thanks
      11-26-2016, 08:18 PM   #2
JOHNNYBRAVO1
NY BRAVEST
47
Drives: 2010 Monaco blue, 335D
Hmmmm, weird. I replaced all of mine, but didn't have that come up. Did you register the injectors and re-do the adaptations? Did you run ISTA D? Maybe 1 or 2 of the injector connectors isn't seated making contact not shooting fuel?
      11-26-2016, 08:45 PM   #3
natefank
Drives: 335d
No, I don't have ISTA, do I need to? I swapped #1 like 6 months ago and didn't have an issue
      11-27-2016, 11:51 AM   #4
glitdi
Rudolf/German/Compression Ignition Specialist.
53
Drives: 2009 335d
So let me get this straight...you swapped an injector and your getting a boost code and a maf code?
You sure they are connected? I sure don't think they are... if you swapped the injector yesterday, I would check connections on everything you took off.... Its a good place to start.. keep it simple.. an injector code and boost codes are two completely different issues...and you are getting boost codes... You left something off or not connected right...
Also did you code your injector? I am guessing not..
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
      11-27-2016, 12:00 PM   #5
DWR
798
Drives: 2009 335d
What problem(s) were you having before you replaced the injectors?
Did you do something in addition to replacing injectors?
      11-28-2016, 11:50 AM   #6
natefank
Drives: 335d
So the codes cleared up, I think it was cuz somehow my boost line for my WM got disconnected.
The reasons I replaced my injectors was because I was getting injector codes and stubbling at around 1200 rpm and idle
      11-28-2016, 11:52 AM   #7
335dlci
277
Drives: 335d
the injector numbs must be stored in DDE after swapping or replacing.
