F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Lean/Oxygen sensor trouble shooting (F-series N55)
proTUNING Freaks
      11-24-2016, 10:41 PM   #1
harkes
harkes's Avatar
China
1075
Drives: M135i, E39 M5, NSX and AE86
Exclamation Lean/Oxygen sensor trouble shooting (F-series N55)
Hi guys
The other day I had an incident where trims did not respond and my car went lean during a JB4 log. I was told this is because the car went into open-loop caused by a defect oxygen sensor. There was no CEL.
Now, how do I trouble shoot this? How to test if the oxygen sensor is defect and which one it is? I find it hard to believe that something so advanced as the F-series does not throw a code for a faulty O2 sensor?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      11-24-2016, 10:42 PM   #2
harkes
harkes's Avatar
China
1075
Admin. Please move to N55 Engine section - thanks.
(A Dane in China)
      11-25-2016, 12:38 AM   #3
harkes
harkes's Avatar
China
1075
I hear that the Bosch 4.9 sensor should be a better version. Does anyone know if the 11787596924 or 11787596908 is is the 4.9 version, and why the length changes for the same model
(A Dane in China)
      11-26-2016, 07:32 AM   #4
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Different for different wastegate models which have different downpipe so as seen
Pre 7/2013
Post 7/2013
Docrace 6266
      12-17-2016, 09:47 AM   #5
Wires
1644
Drives: 2016 340i xDrive
A failed O2 would toss an CEL error.
You sure anything is actually wrong? It looks like it's doing a throttle cut at high RPM (tire slippage?)
Previously in life, EFI vehicles always went into open loop mode under hard acceleration since O2 sensors did a bad job of reading rich mixture. These cars run pretty lean under load in comparison, so I don't know if the O2 is used for acceleration as well.
      12-19-2016, 09:15 PM   #6
harkes
harkes's Avatar
China
1075
Correct but the N55 is running closed loop - also under WOT.
I have ordered a new O2 sensor - will report if itsolve the problem.
(A Dane in China)
      12-20-2016, 07:04 PM   #7
Wires
1644
Thanks for the insight. I was wondering about that considering the AFR they run under load.
If you hook up an ODB2 diagnostic tool you should be able to watch the O2 readings. They are cyclical (go a little to rich and then back to lean) in a sine pattern. If a sensor is bad, then it won't follow that pattern.
      12-21-2016, 08:15 PM   #8
Wires
1644
I forgot to mention if you had a rich misfire, it will show up lean on the logs as well. Raw fuel in the exhaust is high in oxygen and can give a false positive lean reading.
      06-03-2023, 05:54 PM   #9
NLR
Drives: BMW 235i, 540i
hey Harkes,
I have the exact same issue as you but on the B58 platform, did the o2 sensor solve your issues? sorry for reviving the dead thread but I can't figure out what the issue is.
If the sensor did not fix it, do you know what did?
hope to hear from you!
      06-04-2023, 01:40 AM   #10
harkes
harkes's Avatar
China
1075
Originally Posted by NLR View Post
hey Harkes,
Damn... Loooong time ago. Don't remember ever getting it fixed. Just didn't have the problem after binning the JB4
(A Dane in China)
      06-06-2023, 04:59 AM   #11
rVito
Drives: bmw f30 335i
Pre 7/2013
Post 7/2013
if I used older sensors on newer wastegate car, could that cause running rich?
Search this Thread:
Advanced Search
f30post
