2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) removing old wheel weight sticky foam
      11-23-2016, 11:46 AM   #1
zipphreak
No_Country
454
Drives: m235xi
I was cleaning my wheels last night before swapping over to my winter set, and i noticed when i got new tires they didn't clean up the wheel weights. Not that i would expect them to put the extra effort in or anything
Anyone know what chemical is good at softening this up and removing it?
BM235iW97.00
      11-23-2016, 12:23 PM   #2
overcoil
3074
Drives: M235i 6spd
I use BMW tar remover and BMW natural wax with a microfiber towel. And it takes quite a few applications before it disappears. But I noticed in cold temperatures the sticky glue doesn't want to disolve. That's why I do it when it's warm outside.
Isopropyl alcohol didn't work at all for me. And I refuse to use a plastic scraper or goo gone.
I treat my wheels like my paint, never a bristled brush to clean them.
      11-23-2016, 12:52 PM   #3
zipphreak
No_Country
454
Drives: m235xi
lol thanks. I tried isopro alcohol as well, didn't seem to do anything. I use just microfiber on the face of the wheel, and then i will splurge with a brush on the inside of the wheel when it's off the car. I have a heather in my garage so i can make it warm
      11-23-2016, 05:15 PM   #4
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
heat gun.
www.nybmwcca.org
Current Cars:
1995 M3 Coupe Manual Alpine White
1997 M3 Sedan Auto Cosmo Black Metallic
2018 x3 m40 Auto Grey Metallic
      12-02-2016, 09:55 AM   #5
mdputnam
mdputnam's Avatar
289
Drives: 135i & M235i Convertibles
The commercial 3M General Adhesive Remover 08984, and a 3M 03612 4" x 5/8" Adhesive Eraser Wheel will remove any adhesive known to mankind.
Unfortunately, you can't purchase this commercial adhesive remover in CA; CT; DC; DE; IL; IN; MA; MD; ME; MI; NH; NJ; NY; OH; PA; RI; UT; VA; VI
      12-02-2016, 10:25 AM   #6
zipphreak
No_Country
454
Drives: m235xi
Wow lol.. I found plastic razor blades and gasket remover works too (it's acetone based be careful) Only let it sit for a few seconds, work at it with the plastic razor, and repeat.. It comes off pretty easily repeating those steps.
https://www.amazon.com/Permatex-8019...c+razor+blades
https://www.amazon.com/CRC-05021-Tec...gasket+remover
A bunch of forums referenced the spray version of that product too:
https://www.amazon.com/3M-38983-Gene...hesive+remover
      12-02-2016, 01:20 PM   #7
bryan_G01
bryan_G01's Avatar
1165
dude, heat gun for 5 seconds, comes right off. Nothing to scrape or use toxic liquids.
www.nybmwcca.org
Current Cars:
Appreciate 2
Tpeterson156.50
BM235iW97.00
      12-02-2016, 07:24 PM   #8
zipphreak
No_Country
454
Drives: m235xi
Got it.. I'll try that some other time.. I like toxic chemicals and razor blades.
      12-03-2016, 11:36 AM   #9
zipphreak
No_Country
454
Drives: m235xi
Goo gone is pretty weak. It takes alot of work to get it off, and even once it's off it doesn't remove the final layer of adhesive. So far the gasket remover+ plastic razor blades are the ballz. Maybe next year i'll try that 3m Adhesive Remover, lot of detailing forums swear by it for everything.
FYI, i am removing left off foam/adhesive from the tire shop just popping off the weight. Not entire wheel weights. A heat gun would work much better for that.
      12-04-2016, 06:43 PM   #10
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Tarminator works really well getting the gummy residue off. Spray it on and let it sit for a little bit the you can scrape it right off with a plastic razor blade.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      12-09-2016, 12:33 PM   #11
Maynard
3848
Drives: 228iX & M2C
Careful w/ those chems, to keep them off the tires. Some of these can mess up the rubber, and that could be a real drag if it caused tire failure at the bead.
      12-09-2016, 04:20 PM   #12
zipphreak
No_Country
454
Drives: m235xi
Yah it's not like im spraying this shit willy nilly. You are putting it on a rag or paper towel and carefully applying it
      12-09-2016, 09:12 PM   #13
xantdieselx
Kingslayer
No_Country
411
Drives: 23' M3 Base
Tarminator won't hurt the rubber. It's actually great for cleaning the brake dust off of the sidewalls before spraying protectant (like 303).
      03-17-2017, 07:23 PM   #14
BM235iW
BM235iW's Avatar
97
Drives: 2015 Black Sapphire M235i
For wheel weight glue I use WD40 and towel the glue off. After the sticky is off , wash the wheel barrels and tires.
Tpeterson156.50
      03-22-2017, 08:55 PM   #15
Rayscott
376
Drives: BMW 228ix
Xenit will remove it. Spray on MF cloth and it is gone. Not harmful to wheels or tires.
      03-29-2017, 03:27 PM   #16
crabu2
142
Drives: Truck and ...
I have a wheel balancer at home and all I've ever do is scrape the old weights off. it's just too much work trying to clean the inside of wheel weight goo.. Now if I had wheels where you could clearly see the inside... then in might be a different story..
'20 240ix convertible
2addicts
