BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Slight diesel smell in cabin
      11-22-2016, 08:04 PM   #1
Major_90
26
Drives: 2011 BMW 335d
Hi folks,
There seems to be a slight diesel smell in the cabin. It isn't heavy like I can't breathe or anything but enough to annoy.
What part usually fails to cause this? Or is it normal? Anyone think it would be covered by the 70k/7 year emissions warranty?
2011 335d
      11-22-2016, 08:42 PM   #2
Fork!TheSpoonWrecker
Drives: 2009 335d - Monaco Blue Sport
i have the same thing, ppl say its the weld on the egr cooler most of the time
      11-22-2016, 08:49 PM   #3
Major_90
26
Think that would be covered under the emissions warranty?
      11-23-2016, 04:56 AM   #4
335dsleeper
389
Drives: 09' 335d 10'35D
Yea, check out the EGR cooler in the front of the engine.
      11-23-2016, 08:46 AM   #5
glitdi
Rudolf/German/Compression Ignition Specialist.
53
Drives: 2009 335d
egr cooler, leaky injector, boost leak, crack in the exhaust, intake not on properly, list goes on and on..
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
      11-23-2016, 09:47 AM   #6
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Add the following to the list:
-differential pressure sensor and its two tubes off of DPF;
-exhaust pressure sensor and its connection to the manifold, especially, the rubber portion of the connection.
      11-23-2016, 10:17 AM   #7
davethetenor
Oil Burner
Is there an abnormal hissing sound coming from the engine bay while accelerating?
2011 BMW 335d M sport
      11-23-2016, 08:13 PM   #8
Major_90
26
Hi Folks,
Took the engine cover off and found a slight leak on the left side of the engine. Any idea what it is? Also, any tips on getting the engine cover back in and lining up all the fasteners correctly?
      11-23-2016, 08:55 PM   #9
Zuke737
Drives: 2011 335D Msport/F15 Msport X5
Major, what a small world, I just replaced that line Saturday. The oil runs over the turbo and gives off the smell.
The line was 65$ from BMW dealer.
Good luck
      11-23-2016, 09:29 PM   #10
Major_90
26
Good luck
Ha, perfect! Small world Zuke.
Would you happen to have the part number? Was it hard to change? Any tips?
      11-23-2016, 10:36 PM   #11
Zuke737
Sorry buddy on the part #, but BMW located it fast.
As for install just remove the heat shield and two bolts, easy.
I did spray the engine down with cleaner after, but I got cleaner smell coming in now.
Have fun,
Kent
      11-24-2016, 12:31 AM   #12
Yozh
Yozh's Avatar
No_Country
870
Originally Posted by Major_90 View Post
Hi Folks,
Why don't you start your car with the cover off and let someone rev it for you and you with a flashlight can see where the smoke is coming from.
Just make sure you differentiate between the burn oil smell and raw diesel smell.
Appreciate 2
      11-24-2016, 12:35 AM   #13
Yozh
Yozh's Avatar
No_Country
870
11427795971 for the pipe,
you need four (4) new copper crush washers 07119905041
Husker has them for a good price:
http://www.bmwdirectparts.com/oe-bmw/11427795971
If you are good with tools you can just do the change by unfastening the top bolt on the turbo heat shield and do it that way.
      11-25-2016, 07:29 AM   #14
sgrice
Drives: 2018 X3 M40i 2010 X5 diesel
I have a 35d (essentially same engine) which had a similar issue. In my case, one of the upper turbo bolts had fallen off, and another was extremely loose. You can read my experience here:
http://www.bimmerfest.com/forums/sho....php?p=9503808
Of course, the loose turbo bolts might not be your issue. On the other hand, I discuss how to get the turbo heat shield off to get to the turbo oil line.
Hope that helps.
      11-25-2016, 08:42 PM   #15
Major_90
26
Thanks Yozh and sgrice!
Do you think this part would be covered under the CA 7 year/70k emission warranty? May as well ask, right?
      11-25-2016, 09:14 PM   #16
temporaptor
temporaptor's Avatar
64
Drives: 11 335D MSport / 12 X5 35d
      11-25-2016, 09:22 PM   #17
Major_90
26
Didn't think so either.
Ordered from bmwdirectparts.com You guys have good experiences with them?
      11-25-2016, 10:33 PM   #18
Yozh
Yozh's Avatar
No_Country
870
They are great. Prices for OEM stuff are the best. Shipping sometimes may take a tad longer cos they may have to go source parts. However, for some things Bosch, etc. you can find a Bosch pn and get non-BMW labelled part for cheaper. I think ECS carries them.
      12-03-2016, 04:31 PM   #19
Major_90
26
Alrighty, just replaced the line. It was a little tricky so I ended up removing the air filter and housing. I didn't removed the furtherest bolt that holds the heat shield as I managed to pull it up just enough to get the bolt off (also just looking at that made me not want to go through the trouble). The whole area was covered by a light amount of oil so I hope this solves the problem.
Question for folks, is this specific oil line the one that usually fails or could it have been a couple of them?
      12-10-2016, 12:24 AM   #20
ASBSECU E93
Know's a guy that know's a guy...
ASBSECU E93's Avatar
5637
Drives: 2010 335d; 2008 135i
So - with full ABC delete, EGR block - why would a slight smell still be present with heater on..?
Originally Posted by Lups View Post
She stood there. Pointed a finger at me and laughed at me. That damn bitch.
Poop shit, shit and poop. I'm mildly angry now.
      12-10-2016, 10:58 AM   #21
Owen81
83
Drives: 335d, 17/22 TDI
Smell your tail pipes?
Some have said the down pipe connection can leak slightly as well, and you should put copper anti-seize on the metal gasket. I didn't and I get quite a noticeable smell right away with the recirc off.
      12-10-2016, 08:27 PM   #22
Greck
Greck's Avatar
59
Drives: e90 2011 335d / e70 2011 35d
What do you mean, connection with SCR cat or engine-dpf?
