11-18-2016, 08:02 PM | #1 |
Bates '08 Interlagos Launch
126
Rep 1,230
e92 M3 wheels on a GT?!
I have a e92 M3 and I'll be selling it soon. Does anyone know if the wheels from it will fit my 2016 GT? I'm assuming the ET will be off etc.. but how badly?! I know some of you wheel savants will know !
pics?!
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
11-25-2016, 07:41 AM | #2 |
2760
Rep 5,483
I have an e90M and a 335xiGT. Fronts might work rears probably won't offset is too low. And the M3 tires are obviously staggered too much for an xdrive car there's 3/4" difference in diameter
11-25-2016, 09:22 AM | #3 |
126
Rep 1,230
ok thanks..
11-26-2016, 07:31 AM | #4 |
30
Rep 516
which model GT? I have a 335i and the main issue was clearing the front brakes. if you have smaller brakes it may work, ignoring the staggered issue...
07 e90 335i 13 mk6 GTI 13 f30 335i |
11-29-2016, 03:52 PM | #5 |
2760
Rep 5,483
Stock e9xM front brakes are 360mm with the very large sliding calipers BMW used on most of its big power cars till recently. Stock 335 F30 front brakes are 340mm (unless equipped with the M PErformance brakes which are an accessory/port installed and not a factory fitment). Any E9xM front wheel should fit over the F30 335xi front brakes with lots fo room to spare. Hell I have a set of 17's that fits easily over our F34335xi's stock front Brembos; they can't even get close enough to the hub to touch my studs on my E90M.
11-29-2016, 05:26 PM | #6 | |
126
Rep 1,230
The caliper clearance should be ok for sure.
11-29-2016, 10:27 PM | #7 |
2760
Rep 5,483
Yes 25.7" front 26.3" is the stock diameter on the e90m. Need to use tires within a couple tenths of an inch front to rear on xdrive cars. Not to mention the short front tire would look goofy on a GT thats more than an inch shorter than the ~27" stockGT tires
12-13-2016, 10:02 AM | #8 |
126
Rep 1,230
Put them on, went for ride, seems to handle a lot better than stocker run flats.. using lm32 snow tires. It looks a little goofy, Ive seen worse, but ill run the rubber out and save the cash.
https://flic.kr/p/Q17KjR Only crappy part is the tpms from me e92m3 dont work on the new cars..
