11-18-2016, 05:25 PM | #1 |
23
Rep 66
Anyone have video/sound clip of just a resonator delete?
Looking for some video or sound clips of just a resonator delete on a 235. I just want to check out how much louder its going to be. I also have a catted dp so if anyone is running that combo, video of that would also be much appreciated. Thanks!
11-18-2016, 07:02 PM | #2 |
1165
Rep 1,931
search...
this has been answered and asked again 100s of times. than go to you tube and look up m235 delete for 100s of videos.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-18-2016, 09:07 PM | #3 |
23
Rep 66
Did that....a lot of vids on youtube of res. delete and an aftermarket axleback or muffler deletes but can only find one vid that is res delete only which is from a 435i. Same with this forum...i cant find any that is just res delete only. Sure there are plently of discussions but havent found a vid yet. Every vid ive found is all mated with an aftermarket exhaust of some kind. Just wanted see if theres another vid out there besides the 435i one. I think you're getting confused with a muffler delete which there are 100s of videos.
11-22-2016, 05:21 PM | #5 |
625
Rep 1,753
Res delete alone won't make that much of a diff.
11-22-2016, 05:46 PM | #6 |
Rep 16
11-22-2016, 09:21 PM | #7 |
23
Rep 66
Thanks guys. All i want is a little more sound. Just seein' if its a viable route to go on the cheap rather than spend for an axleback. The sound may be enough for me.
11-22-2016, 09:49 PM | #8 |
625
Rep 1,753
I'd put the money into an intake first. Not exactly an upgrade to the exhaust sound, but it does add a lot. Then save money for a decent axle back. If you can find a shop that will do it you may want to consider gutting your stock exhaust. Remove the stuffing from the first and third chamber and swap out the perforated pipe with solid pipe. Resonator alone will not net that much. No shop here would do it claiming that the metal is too thin to weld shut.
JoyRin23.00 |
