11-16-2016, 10:33 AM | #1 |
114
Rep 469
Sold
Afe scorcher module Part # 77-46304 Fits N55 motor and different years and body styles Asking $230 obo AFE Scorcher Power Module Fit For N55 Turbo Engine 2011-2013 BMW 135i (E82/E88) L6-3.0L N55 2013-2014 BMW 135is (E82/88) L6-3.0LN55 2012-2016 BMW M135i/ix (F20/21) L6-3.0L N55 2014-2016 BMW M235i (F22) L6-3.0L N55 2011-2013 BMW 335ix (E9x) L6-3.0L N55 2012-2015 BMW 335i/ix (F30) L6-3.0L N55 2013-2015 BMW 335i/ix (F31/34) L6-3.0L N55 2014-2016 BMW 435i/ix (F32/33/36) L6-3.0L N55 2011-2016 BMW 535i (F07/F10) L6-3.0L N55 2012-2016 BMW 640i/ix (F12/13/06) L6-3.0L N55 2012-2015 BMW 740i/Li/Lix (F01/02) L6-3.0L N55 2012-2015 BMW X1 35ix (E84) L6-3.0L N55 2013-2016 BMW X3 35ix (F25) L6-3.0L N55 2015-2016 BMW X4 35ix (F26) L6-3.0L N55 2011-2013 BMW X5 35xi (E70) L6-3.0L N55 2014-2016 BMW X5 35i/xi (F15) L6-3.0L N55 2011-2014 BMW X6 35xi (E71) L6-3.0L N55 2015-2016 BMW X6 35i/ix (F16)L6-3.0L N55 Color: Black Features: ? Direct Plug In Power: This simple and safe plug and play module adds instant power by altering pressure sensor signals to increase boost to an optimum level throughout the entire RPM range. ? Blue L.E.D. Power light: This module comes with a built-in blue L.E.D. light to show your module is powered up and functioning correctly. ? High Precision and Reliability: Scorcher modules are 100% tested, have output protection on all signals and are built to a 0.1% tolerance on components in critical areas. Signal filtering is used for a smooth response. These modules work great on vehicles in stock trim but are optimized to maximum performance with use of aFe Power performance parts (intakes, filters, exhaust, etc.). ? High Quality Materials: aFe Scorcher modules use OE style "all weather" connectors which require no modification to your factory harness, providing a secure factory-style fit and hassle-free installation. The housing is constructed of aluminum with a hard coat black anodized finish and uses Automotive grade TXL wire with high heat and chemical resistance. Scorcher Modules come with a 2-year limited warranty. ? Sensor 2 Style: The BMW N55 came with two types of TMAP/MAP Sensors. This Module accommodates the Sensor 2 style. The Sensor 2 TMAP/MAP sensor is identified by having a gray connector clip and no raised square located between the mounting bolt locations. The TMAP sensor is located on the drivers side of the engine, mounted on the intake tube between the factory air box and the strut tower. |
