11-15-2016, 05:40 PM | #1 |
23
Rep 91
Drives: M235i & X1 2.0d
235i engine mounts
Hi,
Does anyone know if there is a high performance engine mount to be found anywhere for a 235? I know it shares it mounts with 135, 335 and 435, but can't seem to find anyone offering for any of these? Poul |
11-15-2016, 06:04 PM | #2 |
289
Rep 864
High Performance=STIFF
Do you mean that you are looking for a stiffer design which will not allow the engine to move / torque and thus provide a quicker moment of force to the drive shaft on hard acceleration. I guess you would call this a part of drivetrain loss??
11-15-2016, 06:44 PM | #4 |
1165
Rep 1,931
Turner has the engine and tranny mounts for the m235R.
Check them out. M235iR Engine and Transmission Mounts This kit from BMW Motorsport stiffens the engine and transmission mounts so they will not wear or fail prematurely on the race track. Rubber mounts are great for street use where they soak up vibration and harshness. But the rubber quickly loses its strength under racing conditions. BMW Motorsport has developed this stiffening package consisting of a solid insert for the stock motor mounts and new solid transmission mounts. The insert is a solid material that reinforces and stiffens the stock engine mount. Although new engine mounts are recommended they are not required if you have low mileage rubber mounts in good condition. The transmission mounts are direct replacements made from solid aluminum. The transmission mounts work on manual and automatic transmission models. Because these are solid mounts they are not street-friendly and more noise and vibration will reach the cabin. M235iR Engine And Transmission Mount Set ($477.94)
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
x233284.00 |
11-15-2016, 10:38 PM | #5 |
23
Rep 91
11-15-2016, 10:39 PM | #6 |
23
Rep 91
11-15-2016, 10:54 PM | #7 |
23
Rep 91
[QUOTE=bryan_f22;20856417]Turner has the engine and tranny mounts for the m235R.
Check them out. M235iR Engine and Transmission Mounts This kit from BMW Motorsport stiffens the engine and transmission mounts so they will not wear or fail prematurely on the race track. Rubber mounts are great for street use where they soak up vibration and harshness. But the rubber quickly loses its strength under racing conditions. BMW Motorsport has developed this stiffening package consisting of a solid insert for the stock motor mounts and new solid transmission mounts. The insert is a solid material that reinforces and stiffens the stock engine mount. Although new engine mounts are recommended they are not required if you have low mileage rubber mounts in good condition. The transmission mounts are direct replacements made from solid aluminum. The transmission mounts work on manual and automatic transmission models. Because these are solid mounts they are not street-friendly and more noise and vibration will reach the cabin. M235iR Engine And Transmission Mount Set ($477. Thanks! Been trying to find these! Ideally I'm looking for something like in this photo, but the last model they cover is the e9x series M3. It's in between the solids and the original. ... and then came the... enter a URL for your photo... I'll upload from another unit. |
11-16-2016, 11:44 AM | #8 | |
23
Rep 91
[QUOTE=Pnorth;20857178]
11-16-2016, 12:01 PM | #9 |
23
Rep 91
I have written Vibra Technics in the UK today to ask if the do plan on making any, as the engine mount in my F22 cover all the models from F20 up to the F87, via the entire F3X series, including M3 and M4. I'll post their reply.
11-16-2016, 12:03 PM | #10 | |
23
Rep 91
I am rebuilding slightly crashed car with 14000 km on it. I can see a slight "wrinkle" on the rubber in the mount and hence want to replace them. This is why I am searching for something "semi-rigid". |
11-19-2016, 04:09 PM | #11 |
1330
Rep 2,214
Those M235iR mounts are on my wishlist, now. Wasn't aware they were available!
The OEM mounts are horrid, as are most OEM mounts in these cars, just way too much slop (especially on a MT) for my liking.
11-19-2016, 07:00 PM | #12 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Unless you're a track rat and don't car about comfort the NVH will be horrendous. There's some polyurethane mounts but will make the car so harsh on the street.
FBO-PS1 and stuff
11-19-2016, 07:03 PM | #13 |
1165
Rep 1,931
Can always dip the metal in rubber to coat them...
www.nybmwcca.org
11-21-2016, 02:03 PM | #14 |
1330
Rep 2,214
I wish someone could take the factory mount, and replicate it with a higher durometer rubber. 034 Motorsports does this for the VAG community. Gotta be someone in the BMW crowd to implement something like that?
11-22-2016, 06:34 AM | #15 |
1779
Rep 4,516
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
11-22-2016, 04:44 PM | #16 | |
23
Rep 91
[QUOTE=Bee Pee;20884738]
Anyone tried these? Looked them up on their web and the look of the products in picture doesn't seem correct. Had a look at the install guide you find at the bottom of the page and found that to be for a GM car, so I guess it is not the right picture? Wrote and asked. P Last edited by Pnorth; 11-22-2016 at 05:07 PM.. |
11-22-2016, 04:51 PM | #17 |
454
Rep 986
I think this is very new territory for most members. You have to track the car to really require the need for something like this. Plus i doubt it's a simple DIY you can do on ramps.
11-22-2016, 05:08 PM | #18 |
23
Rep 91
Vibra technics customer service seems to be out on vacation - haven't heard anything yet.
11-22-2016, 05:10 PM | #19 |
23
Rep 91
11-23-2016, 12:58 PM | #20 |
1330
Rep 2,214
DIY or not, if you have a MT car, you'd understand why we want better mounts. You don't feel the same weight transfer with an Auto transmission. I agree we don't need full on race mounts, but we do require a better mount option at the end of the day. The platform is still relatively new, so I'd imagine we'll have more out there in the coming years.
11-24-2016, 02:27 AM | #21 |
Tea wot?
210
Rep 271
I had vibratechnics mounts very similar to those pictured above on a previous car.
The solidity added to the drivetrain was fantastic. The NVH and bolts rattling themselves loose regularly was not so fantastic. They are way too stiff for a road car IMO. What we need is some OEM style mounts with stiffer material than the stock rubber, like a poly insert rather than rubber. Last edited by Sam_M; 11-24-2016 at 02:33 AM.. |
11-24-2016, 04:31 AM | #22 | |
23
Rep 91
They apologized for the inconvenience and were going to fix this on their web. They do not have anything in the pipeline either. |
