Water on drivers side front
11-14-2016, 02:31 PM | #1 |
Rep 12
Whenever it rains I get a little bit of water at the bottom of the "foot rest". I have checked the sunroof drain and it is connected (the only section I know to check is up in the headliner). Can anyone please help!!!
E90, N54, JB4, BMS DCI
11-14-2016, 04:08 PM | #2 |
228
Rep 455
Drives: '19 X3 M40i
Subscribed. Mine's done this for years... I started with pulling down the headliner, checked all the sunroof-ish stuff, no change.
I have gone into a car wash and poked around, the only lead I have is the water seems to trickle in from underneath the forward corner of the drivers door, most likely down from the a-pillar edge. I don't see anything obviously funky with the various seal overlaps, but clearly something's not right.
2019 X3M40i DGM/black vernasca, 2T4, 2VF, ZPX, ZPP, ZDA, DWS06+, etc, etc. Since July'19.
2021 X540i MSport CBM/black merino, 337, ZMP, ZPP, ZPK, etc. Since Dec'20. 2006 330i SGM/black, ZSP, ZPP, 217, HuberOps, M Splits, K Lines, AS 3 on EC-7. Sep'08-July'19. |
11-14-2016, 04:51 PM | #3 | |
25
Rep 116
http://www.e90post.com/forums/showpo...4&postcount=10 Exact same leak you are showing in your pic. Check your vapor barrier. It is probably unsealed in spots. NOTE: I also tried heating up the existing glue on the door to no avail... leaked again so the only real solution for me was the silicone.
'11 BMW///335i Sedan
Black Sapphire Metallic|Dakota Blk Lthr|Sport Seats|M Sport Sus PKG|Nav| '02 BMW ///M3Imola Red|Blk Cloth|6M|TFS CSL TUNE - MSS54HP|CSL Rep Airbox|Euro Headers|StopTech ST-40 BBKs|Kirk 4pt Bar|CF CSL Trunk|GC Race F/R Sways| |
11-14-2016, 04:54 PM | #4 | |
447
Rep 1,060
11-14-2016, 04:59 PM | #5 | |
25
Rep 116
Your leak sounds like the classic "cowl shield" not being seated or something with the entire set of shields on the lower portion of the windshield and under hood area where the climate control intake is will probably be out of sorts. several threads on that too: http://www.e90post.com/forums/showthread.php?t=411641 EDIT: Found a tube link with the issue I suspect you have for your leak:
Black Sapphire Metallic|Dakota Blk Lthr|Sport Seats|M Sport Sus PKG|Nav| '02 BMW ///M3Imola Red|Blk Cloth|6M|TFS CSL TUNE - MSS54HP|CSL Rep Airbox|Euro Headers|StopTech ST-40 BBKs|Kirk 4pt Bar|CF CSL Trunk|GC Race F/R Sways| Last edited by Hacksaw; 11-14-2016 at 05:14 PM.. |
11-14-2016, 07:28 PM | #6 | |
Rep 12
11-14-2016, 10:06 PM | #7 |
392
Rep 2,367
Drives: 2011 335i
Haha time to replace that sticky icky in the door seal
