11-14-2016, 10:56 AM | #1 |
625
Rep 796
M2 tuning and log thread
Hey everyone. I thought it would be nice to setup a place where people who monitor and log their cars could share information and findings. A couple questions I would like to see answered.
What's your stock boost looking like when the car isn't pulling timing? And what is your tune running at? Any custom map 6 guys out there? My experience with my FBO JB4 car is a little concerning and seemingly throws the old N55 limits out the window even on map 1. So what are the new safe limits? Map 1 FBO running with overboost puts us at a 4psi over stock target. Which means our cars on map 1 are running at or above an m235i or equivalent n55 car in map 7. My stock boost will hit 14-15ish PSI which brings us close to 19-20psi in the midrange. Map 2 is the 6psi target. Which seems overkill but my HPFP will hold me off from utilizing it. What I did find with JB4 is if you run mafless the DME and ECU targets drop to around 12psi max right where the stock overboost starts to creep up usually. I will post a mafless map 2 run, I'm thinking this could be the reasonable kill map assuming the octane and HPFP hold up. |
11-14-2016, 08:00 PM | #2 |
IG @bmwF9xG80
3812
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Looking forward to your logs, you prob have seen mine in other threads for the X4 M40i.
I've worked a little with DKM3Power M2 Manual and cars are very funny when seeing jb4 logs. In this regards I've joined proTUNING Freaks Bootmod3 with our local tuner Enzo Performance.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
ashburyn54624.50 |
11-14-2016, 08:09 PM | #3 |
3179
Rep 2,577
What's the overboost over stock that you hit at top end on map 1?
Lemania 2320
ashburyn54624.50 |
11-14-2016, 08:12 PM | #4 |
342
Rep 1,122
Very interested as well just got my jb4 and plan on using bm3 as a BEF
ashburyn54624.50 |
11-14-2016, 08:41 PM | #5 |
292
Rep 254
Finally a thread on this side of the fence. Love n54tech but bimmer post needed this thread for the M2's. Thanks for starting it ashburyn54. Car arrives next week and I have an aggressive mod plan that should have my car completely "finished" by 5k on the odo lol. BM3 is in BETA which should wrap up soon I'd think. They are also working on an IOS version of there app which will be nice. Right now I am strongly leaning towards a complete BM3 flash solution instead of the traditional JB4 with BEF.
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough 2008 VW GTI - first experience with boost 97 Integra GSR - crashed it |
ashburyn54624.50 |
11-14-2016, 08:42 PM | #6 | |
625
Rep 796
11-14-2016, 08:45 PM | #7 | |
625
Rep 796
I'm excited to see what BM3 can do moving forward. Not having to "trick" the system would be amazing. |
Norcalmav23292.00 FSociety3811.50 |
11-16-2016, 06:52 AM | #8 | ||
IG @bmwF9xG80
3812
Rep 7,593
So far in less than a week I activated, sent my stock file to them, all tables defined & OTS queue is moving.
11-16-2016, 07:19 AM | #9 |
BimmerPost Supporting Vendor
966
Rep 13,780
We also have the ability to unlock the DME for Bootmod3, we can flash tune, we can log for you, we can dance.....well at least i can...
ashburyn54624.50 |
11-16-2016, 06:47 PM | #10 |
625
Rep 796
jeff@autocouture965.50 |
11-16-2016, 07:01 PM | #11 | |
625
Rep 796
I think it's time for some map 6 tweaking. I don't like a 6psi additive target so low in the rev range. It's like a kick in the teeth. I'll try a more linear curve with a small taper and will post those as well. |
FSociety3811.50 |
11-17-2016, 11:49 AM | #12 |
342
Rep 1,122
Finally got jb4 installed and did some pulls. Car didn't fell right and can feel throttle closure throughout the pull. It did get better by the 3rd pull so not quite sure how much this is from "learning/adjusting" to the map. This on 91octane with catless DP and Dinan exhaust. Sent it over to Terry for advice and adjustments.
11-17-2016, 11:52 AM | #13 | |
625
Rep 796
Another way of smoothing things out is lowering your PID gain. Lowering to 8 versus 10 smoothed things out for me drastically. |
11-17-2016, 01:45 PM | #14 |
342
Rep 1,122
Having trouble loading the files on here. I did all 3 pulls pulls in 3rd gear starting at 2rpm to redline all on map 1 in sports+. This morning I put in 2 gallons of e85 and it's now running much better but still feel some hiccups here and there
11-17-2016, 02:18 PM | #15 |
IG @bmwF9xG80
3812
Rep 7,593
Check your User Adjustments
Boost Safety if its at 18 (increase to 2) PID Gain: 10 Defaulte Watergate POS: 0 FF/Waste Adaptation: 0 FOL: 60 Auto Shift Boost Redux: 10 Rest leave blank And most importantly UPDATE to firmware EWG9.hex if you haven't already Best way to get logs support is n54tech.com And personally have not seen any great results with JB4 on M2.. Already know 3 guys in this hole.
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 11-17-2016 at 04:57 PM.. |
11-17-2016, 02:57 PM | #16 |
625
Rep 796
Try with traction fully off and see if some of the closures go away.
11-17-2016, 09:56 PM | #17 | |
342
Rep 1,122
11-17-2016, 10:01 PM | #18 |
IG @bmwF9xG80
3812
Rep 7,593
When you go to Settings > Firmware it will take you to n54tech.com zoom in 2nd choice is N55, B58, click there, zoom in again, click 4th choice (F Series N55 Jb4) sticky) , zoom in a start scrolling slowly before end of 1st post you will see EWG9.hex
Click it, it downloads in 5 seconds (small file) and go back to your car and flash it, car must be turned off but on battery(standby mode or accessory mode)
11-17-2016, 10:15 PM | #20 |
IG @bmwF9xG80
3812
Rep 7,593
Just saw your log you have N54 E Series selected as your engine type
Btw dont modify the log, leave it as csv since thats the correct format to open it with JB4 App anyhow recommend you going to n54tech.com and uploading your logs there ASAP
11-18-2016, 01:24 AM | #22 |
625
Rep 796
Oh shit. That doesn't even make sense lol
