Key Fob Trunk Button Not Opening Trunk
11-14-2016, 09:45 AM | #1 |
321
Rep 1,157
Sometimes this car does weird things that I just don't understand. This is one of those things. I have comfort access, and that works fine on all the doors, and works about 60% of the time opening the trunk. The other 40% I have to unlock the car before trying to open the trunk. The button on the key fob to open the trunk doesn't open it for some reason. If I hold the button down it sets off the alarm, but just pressing it does nothing. Thoughts?
11-14-2016, 10:27 AM | #2 |
765
Rep 3,556
I also have comfort access. Pretty much what you say happens to me as well. I have had luck if I push trunk button multiple times though. Most of the time if it doesn't open by squeezing the rubber button, I also push the unlock button. Either way, it's a button push (trunk button or unlock button) so I don't stress.
Minor thread jack/sorry: My key fob went for a swim a couple summers ago though. I attribute my intermittent problem to this. The fob eats batteries now in about ~6 weeks. I have cleaned it with isopropyl alcohol 2 or 3 times and let dry. After initial "swim", I put it in a bowl of rice for about a week. It works fine except just hard on the batteries. The swimming pool was a salt water type so I think I've got some parasitic current leakage across some where in there. I don't know how to fully open up the green board for cleaning so I used Qtip up inside the battery rubber seal thing. I have a back up fob that just recently needed a new battery and is now fresh. I will try it with trunk to see if same trunk button issue is still there. |
11-14-2016, 02:09 PM | #3 |
171
Rep 504
Try holding it for ~3 seconds. I hold it down, count till 3 and let it go and it pops open. Holding it for 4 seconds or longer sets up the alarm.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
11-14-2016, 02:52 PM | #4 |
870
Rep 2,615
If you have anything that may interfere with the signal, that will make for an intermittent issue you are experiencing. Cell phone, a wallet in the same pocket. Try opening your trunk with key in a hand, close to the car, usually opens without a fuss.
