Brakes and Brake Accessories
11-11-2016, 10:14 AM | #1 |
321
Rep 1,157
So my car is coming up on needing rear brake pads. iDrive says 1300 miles, but the squealing noise says now. Should I go OEM or upgrade to different pads? What does everyone suggest? Rolling stock right now, but will be getting a Stage 2+ in a year or so. Don't want to do a full brake rework since the front pads still have lots of miles(38000, says iDrive) left on them. Don't want to spend tons of money on them, at least no more than OEM. I heard stoptech is good. Are those okay on OEM rotors? Street Pads or Sport pads? What about brake fluid. iDrive says I've got like 6 months. Should I go ahead and do it now? What fluid should I use? Is it a really hard DIY job? Thanks!
11-11-2016, 10:33 AM | #2 |
277
Rep 1,575
please note: the mileage is not always correct. it is just a rough estimate of remaining mileage of brake pad left. brake pad squeal can occur when you have 7.5mm of pad remaining...you don't have to wait 6 more months to change your fluid. its perferrable to use a pressure type of brake bleeder to bleed the system. I can not comment on non oem brakes from my personal experience.
11-11-2016, 10:35 AM | #3 |
111
Rep 529
lots of discussions about brakes in the Brake / Suspension section.
http://www.e90post.com/forums/forumdisplay.php?f=38 I am in a similar situation and have been reading up on suggested upgrades. Unless you are tracking your car, the consensus seems to be to keep the stock calipers and upgrade rotors and pads. Main reason cited for upgrading pads is to have less dust. I personally will be going OEM because I do not see the need for upgrade on my DD.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) |
11-11-2016, 10:41 AM | #4 |
166
Rep 460
Zimmerman rotors (oem), oem pads.
11-11-2016, 08:11 PM | #6 |
321
Rep 1,157
I guess the brake kits on FCP Euro are looking pretty good, and the price is hard to beat. Zimmerman rotors and Akebono pads. As for the brake fluid, how hard is it to do myself? ECS has a brake fluid kit that comes with a bleeder and 1 liter of fluid. Any good DIY guide I should look at? I'd be more than willing to do all of my brake work in one go.
11-11-2016, 10:12 PM | #8 | |
277
Rep 1,575
11-11-2016, 10:32 PM | #9 |
765
Rep 3,556
I just did the fluid change using the pressure unit made by Motiv from idparts.com. The 45 mm cap fit the master cylinder perfectly. I will be doing rear brakes soon pending a UPS delivery getting rectified. They lost the rotors. I used close to 1 liter of DOT 4 fluid. I had fluid changed 2 yrs ago but it was still very clean looking.
11-11-2016, 11:09 PM | #10 |
321
Rep 1,157
Maybe I'm uneducated, but I've never experienced bad brakes. IMO if they get me from 80 to 0 in a reasonable amount of time, I'm good. I don't have a need to really use my brakes heavily ever. Engine braking and coasting get the job done for me most of the time. If I do it right, I can get through my commute without using my brakes at all. So as long as they get me stopped, I'm happy.
11-11-2016, 11:13 PM | #11 | |
321
Rep 1,157
11-12-2016, 06:35 AM | #12 |
Warrant Officer
375
Rep 1,341
Think I've gone through 3 sets of rotors and pads on my car so far. The ones I like the most are my current ones, and I bought them from a vendor on here. Think they were $560 shipped for the drilled ones.
The Stop techs I had were pretty soft on the initial brake, but they still gripped the rotor pretty well.
Deleted, ATM I/C and tuned by B.R.R.
11-12-2016, 07:25 AM | #13 |
765
Rep 3,556
First, I used a turkey baster and removed most of fluid form master cylinder. Then I filled it back with new. I put fluid in bleeder reservoir and pumped it to where most of the tube leading to the adapter cap was full of fluid. Next, installed bleeder cap on master cylinder and pumped it to 20 psi. I then bled from farthest caliper first (right rear). I sometimes had to go repump up the reservoir to same beginning pressure. Don't let reservoir go empty. I had to open and add fluid half way through all 4 wheels.
After RR, I did LR then RF and last LF. Go search on net as there are several good videos on this. Be super careful with not getting fluid on paint. I put several towels around area of master cylinder. Pedal felt no different before versus after. |
11-12-2016, 12:08 PM | #14 |
Kind of a Big Deal
167
Rep 857
You will be surprised by how easy to the process is with a power bleeder. You do not even have to remove the wheels although it makes the process easier and is a good opportunity to rotate tires. Having a little fluid catch bottle makes life easier especially if it has a magnet on it so you can stick it on the hub.
I have OEM pads and have never had an issue including track day. No problems with dust although I think there was a changeover (I'm late 2011) and earlier formulations were dustier. |
11-12-2016, 11:57 PM | #15 | |
321
Rep 1,157
11-13-2016, 08:01 AM | #16 | |
765
Rep 3,556
11-13-2016, 05:02 PM | #17 | ||
Warrant Officer
375
Rep 1,341
11-13-2016, 09:42 PM | #18 |
321
Rep 1,157
So I'm at a loss here. First, does anyone know if 335i and 335d brakes are interchangeable? It looks like the rotors are the same size, but are the pads also the same size? R1 Concepts is having a sell on drilled and slotted rotors, along with either ceramic or semi-metallic pads. $400 shipped for front and rear everything is hard to beat. I really love the look of drilled and slotted rotors. Would y'all reccommend ceramic pads, or semi-metallic pads? Any specific fluid I should use, or does it really not matter? Looks like a great time of year for sales, so why not go all out?
11-14-2016, 08:14 AM | #19 | |
357
Rep 1,723
'09 335D
11-14-2016, 12:28 PM | #20 |
229
Rep 3,489
Drives: Montego Blue 335d
Stop Tech Cross Drilled Rotors along with OEM calipers and Hawk HPS pads cant go wrong except a little dust now and then
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
11-14-2016, 02:30 PM | #21 | |
Warrant Officer
375
Rep 1,341
11-14-2016, 02:39 PM | #22 |
171
Rep 504
In the past was able to 'flash' the ceramic pads with hard braking. This time i went with Zimmerman cross drilled rotors and Hawk HPS pads (which are semi metallic). I also switched to SS brake lines and Motul RBF 600.
Breaking is phenomenal now.
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
