11-10-2016, 01:25 PM | #1 |
662
Rep 1,447
My f32 m sport blue calliper brake is squealing like hell during low speed braking
Took it yesterday to dealer, they said nothing wrong, suggested a 180 dollar brake service. Wtf! If nothing wrong why service? (Brake not covered in canada) Took it to a ind shop today, they suggested machining the rotor. The rotor is not smooth. Should I do it? -----------1- Update 2016/11/20 Lube the front. Not really work. I do feel uneven and bit rough on the front rotor. Should i machine it? Can it be re surfaced? I compare it to the x1 next to me. His feels smooth compare to mine |
11-10-2016, 02:27 PM | #2 |
127
Rep 764
I believe they're correct in saying that this is normal. Don't think anything can really be done. Maybe change out your pads/rotors if you're unhappy with them. Then again, your indy might be right. Up until this year, I had absolutely no brake squealing issues.
11-10-2016, 05:34 PM | #3 | |
1610
Rep 3,947
You just need to clean and re-apply some Permatex: https://www.permatex.com/products/lu...s-lubricant-2/ |
11-10-2016, 05:48 PM | #4 | ||
662
Rep 1,447
11-12-2016, 08:04 AM | #5 |
3575
Rep 10,352
RU sure it's the rotors and not the back of the pads? IMO I would have the shops take off the pads, clean the backing them with brake cleaner and use an appropriate anti-squeal compound. I've read that the factory applied material is insufficient.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
11-12-2016, 08:58 AM | #6 |
662
Rep 1,447
11-15-2016, 10:44 AM | #7 |
1610
Rep 3,947
See attached PDF from ISTAD Rheingold documentation. It illustrates where exactly brake lubricant needs to be applied with the appropriate diagrams.
11-15-2016, 11:06 AM | #8 |
662
Rep 1,447
I had the front done but still squeaking, just a bit better. Do rear too?
11-15-2016, 02:09 PM | #9 |
1610
Rep 3,947
11-17-2016, 02:33 PM | #10 |
662
Rep 1,447
11-17-2016, 04:02 PM | #11 | |
1610
Rep 3,947
The real problem is improper installation. I've run M Sport Brake Option pads as well as M3 pads and have zero noise issues. I let the brake lubricant cure/dry for about an hour or two before putting the pads back into the calipers. Are you sure your installer is doing that as well? |
11-17-2016, 04:19 PM | #12 | ||
662
Rep 1,447
11-17-2016, 05:23 PM | #13 |
1610
Rep 3,947
I believe that's the source of the problem.
When the lubricant isn't given enough time to dry/cure, brake pressure from the caliper will squeeze and thin out the layer that makes contact between the pad and brake caliper. |
11-20-2016, 07:24 PM | #14 | |
662
Rep 1,447
11-20-2016, 10:26 PM | #16 | |
662
Rep 1,447
Maybe i should change to a less aggressive pad? Oem or aftermarket? Any suggestions? |
12-19-2016, 08:54 PM | #18 |
662
Rep 1,447
Bought a set of rear textar pads for my f32 with blue m brake. Applied prematex disc brake quiet and clean up rotors. No noise afterwards! Hope it doesn't come back
http://f30.bimmerpost.com/forums/sho....php?t=1336007 |
