ista or gt1?
11-10-2016, 11:08 AM | #1 |
51
Rep 273
ista or gt1?
I'm trying to compare the two, and find one for my 08 E93 335i. I have a tpms transmitter that went out, and have heard that once its replaced, you have to reporgram the system.
Is it hard to do it? Thanks in advance! |
11-10-2016, 11:55 AM | #2 |
529
Rep 2,503
GT1 is very old. ISTA-D Rheingold will help you diagnose the sensor. Not done this for ages but I'm sure it has an option to check battery life etc etc.
I don't think it needs reprogramming. Normally when sensors are replaced you just reset the tpms on the cars computer which will sync the new sensors. |
11-10-2016, 02:19 PM | #3 | |
51
Rep 273
11-11-2016, 09:04 AM | #4 | ||
DOPE
148
Rep 758
I had used sensors from a different car and literally taped them to the outside of the wheel to test, reset the system and took it for a spin. They ended up waking from sleep and worked immediately. |
11-11-2016, 12:05 PM | #5 |
51
Rep 273
11-11-2016, 12:59 PM | #6 |
529
Rep 2,503
This is the RDC trigger. As per BMW Workshop manual, just replace and reset with idrive / BC.
http://workshop-manuals.com/bmw/3_se...__disc_wheels_(rims)/5_ra__removing_and_installing_replacing_an_rdc_tri gger_transmitter_(front)/ |
11-11-2016, 01:26 PM | #7 | |
51
Rep 273
11-11-2016, 04:04 PM | #8 |
529
Rep 2,503
I have never done it but yes, it appears so...
- Start engine but do not drive off - Touch direction indicator lever up or down until the corresponding symbol and RESET appear - Press BC button to confirm selection of Run Flat Indicator - Press BC button for approx. 5 seconds until a check/tick appears after RESET - Drive off. Initialization is completed during the journey |
