Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > AGAIN F@$ck
      11-06-2016, 08:49 AM   #1
335dM
128
Drives: 335d m package
AGAIN F@$ck
So after getting my car back after 2 months because of cbu and overheating!
New head
New turbos
New I/c
New radiator
New t/s
New scr
New nox sensor
Now low end boost gone
Ses reduced power
And still overheating when I'm stopped ( 97-101 degree celsius)
      11-06-2016, 09:02 AM   #2
CvilleBill
24
Drives: 2011 335d
Maybe you'll get a long block this time!
      11-06-2016, 10:54 AM   #3
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
I'd settle for the short block.
      11-06-2016, 12:16 PM   #4
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Is your fan running? Perhaps it was not plugged back in after they replaced the radiator.
      11-06-2016, 01:09 PM   #5
335dM
128
It's doing the same as before!
Nothing changed
Coolant temps doesn't stay at 86 as it should be.
When I stop more than 5-6 mins, coolant goes up, I go on the highway, it takes a good 6-7 mins to get the temp down.
      11-06-2016, 03:07 PM   #6
glitdi
Rudolf/German/Compression Ignition Specialist.
53
Drives: 2009 335d
Nothing changed
How is the water pump?
with a new rad and the fan verified working the water pump is a prime suspect.
Most german water pumps use plastic impellers and after time they can break and disintegrate. General symptoms of this are exactly what you describe, hot at a stop, get moving and the temp drops down again.
I fix other people's stupid German problems so I can afford to fix my stupid German problems....
      11-06-2016, 03:16 PM   #7
Owen81
83
Drives: 335d, 17/22 TDI
Its normal for the coolant to fluctuate. How hot is it getting when idling?
      11-06-2016, 03:17 PM   #8
335dM
128
97-101
      11-06-2016, 03:18 PM   #9
glitdi
53
Drives: 2009 335d
as far as low boost goes I would be diving into the vacuum lines and the boost controler itself, if you have some sort of scan program, go for a drive and see requested boost vs actual boost. I think you need a new dealership... If they took the time to actually do a proper diagnosis instead of throwing parts at the problem you would have a good car and far less complaints.
      11-06-2016, 03:19 PM   #10
335dM
128
I'm still under warranty
Dropping my car to the dealer tomorrow morning
      11-06-2016, 03:56 PM   #11
335dsleeper
389
Drives: 09' 335d 10'35D
^ sounds like you need to have a long talk with the shop foreman.
      11-06-2016, 04:00 PM   #12
Mik325tds
Mik325tds's Avatar
806
Drives: 335d M-Sport
97-101
Those temps are actually normal. I think it is doing this in order to keep the temps in the DOC up to keep it working.
Turn on your AC and see if it goes down to 83 then. That's at least what my car does.
This may just be the reason why they didn't provide a water temp display. With the electronic thermostat they can now control the water temp and move it when it is needed.
Edit: Nonsense. The thermostat in this car is not electronically controlled as @335dwanted points out below. My apologies. However, I have read many posts where people were concerned that the cooling fan comes on around 100°C. So maybe all of our thermostats are bad?
      11-06-2016, 04:23 PM   #13
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
That is the best explanation yet I have seen.
      11-06-2016, 06:14 PM   #14
335dwanted
22
Drives: 2009 335d
My car never hits 212*F with the occasional exception of DPF regen. High 190s, sometimes getting low 200s during normal driving and I have never noticed the coolant temp spiking during idle if Torque app is to be believed. I am also unfamiliar with any electronic thermostat. I know the gassers have an electric water pump which I believe actively manages coolant temps but the M57 has conventional water pump and thermostat.
Mik325tds805.50
      11-07-2016, 07:19 AM   #15
335dM
128
Again
      11-07-2016, 07:28 AM   #16
335dsleeper
389
^ you shouldn't be driving your car, especially in traffic. You're going to do further damage. I hope you at least cranked your heat as hot as it'll go to avoid damaging the head/ head gasket.
      11-07-2016, 07:34 AM   #17
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
I concur with 335dsleeper they can try to VOID any warranty by you driving it under that condition, be careful amigo
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      11-07-2016, 07:42 AM   #18
335dM
128
I'm on my way to the dealer
      11-07-2016, 07:44 AM   #19
Puerto Rican 335d
Puerto Rico
229
oh ok
      11-07-2016, 07:44 AM   #20
335dM
128
Ses just came in on my way to the dealer this morning.
Ses was cause by the absence of low boost.
Probably a bad vaccum line
      11-07-2016, 10:00 PM   #21
JOHNNYBRAVO1
NY BRAVEST
47
Drives: 2010 Monaco blue, 335D
I'd blame the injectors, I went threw this.. new injectors and the D woke up
