What are all the coding tools? What's worth getting?
11-01-2016, 12:53 PM | #1 |
30
Rep 158
I just picked up an e90 after selling my Audi. The primary coding system for Audi's is VCDS which does generally everything you would want, including coding, reading errors and communicating with modules/sensors and reading their data. It's really the only system on the market for Audi's.
It seems that on the e90 there's about a million different systems for communicating with the car. What's the difference between the major/most useful, and which should I get? I'd like to be able to read errors, read data from sensors(if possible on this platform), code, etc. If it matters the car is also experiencing a misfire but hasn't thrown a check engine light, so I'd like to get something to help diagnose that soon. |
11-01-2016, 02:03 PM | #2 |
2124
Rep 2,758
Misfire is most likely plugs or coils if they haven't been changed recently. Carly for BMW is pretty good for diagnostics/coding/battery registration.
11-02-2016, 05:33 AM | #3 |
469
Rep 1,536
Get a K+DCAN cable from a reputable source (cable shack, onestop) and download the V3 Coding VM from here http://www.e90post.com/forums/showthread.php?t=1220039
Carly is quite limited in what it can do. It also costs a lot, the app isn't cheap then you have to buy their hardware. Also the app will screw you for more money for any extra coding changes you may need. It also has a habit of bricking the FRM module. Personally I would stay away from Carly. A battery charger is also recommended for more time intensive coding tasks like module updating. |
11-05-2016, 05:04 AM | #4 | |
30
Rep 158
11-09-2016, 09:59 PM | #5 |
Lord Scrip
1813
Rep 3,013
Drives: 2011 M3 Coupe
K/D-can cable for coding ecu's easily
iCom for updating ecu's easily
