Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > anyone put back swirl flaps back ?
      11-01-2016, 05:49 AM   #1
bayerischer
Drives: 335d e92
so as i mentioned before, i was told swirl flaps are leaking and they were blanked to which I wasn't convinced reading that users experienced power loss and fuel increase, and i can attest those.
now, i want to put swirl flaps back, but as i am reading, i will have to buy new manifold intake?
anyone has done this?
      11-01-2016, 06:24 AM   #2
335dsleeper
389
Drives: 09' 335d 10'35D
What do you base your power loss on?
      11-01-2016, 06:52 AM   #3
Barmlot
13
Drives: 2011 335d
My swirl flaps just failed, in the last 2 months of warranty. I was told that I had to get a whole new intake manifold as this was an integral part. I did notice power loss and fuel efficiency loss about 2 days before i got a CEL. If you watch the MPG gauge it should be pegged at the low end most of the time, even under light acceleration when it would normally be in the 20-30mpg range. Good luck. My SA told me it would have been $1500-1800 without warranty.
      11-01-2016, 07:35 AM   #4
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
I guess Im going thru this crap now, I bought the AArodriguez EGR Race pipe and the Swirlflap covers from him, I will find out this weekend WTF is actually happening to my car. My mechanic got under the car and heard no leaks. Im getting MISERABLE mileage and power, went to a different dyno Sunday and LOST 100 ponies, SOMETHING is wrong i could feel it and BAM the dyno did not lie.
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      11-01-2016, 07:36 AM   #5
MasterC17
329
Drives: 2015 BMW M3
If they're properly coded out I don't see why it would cause power loss or mpg loss. Obviously if they are faulty and/or you remove them without properly coding them out then the car isn't going to run right.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      11-01-2016, 07:39 AM   #6
Puerto Rican 335d
Puerto Rico
229
MasterC17 Im coded out completely. But with the new plugs I believe it will get better HOPE its not the preturbo (crossing my fingers)
      11-01-2016, 08:03 AM   #7
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
PR, you need to specifically ask tuner if flaps were tuned to be open at all times. This isn't necessarily part of the "full deletes" as a default.
      11-01-2016, 08:38 AM   #8
Puerto Rican 335d
Puerto Rico
229
BB_cuda will ask Lenny that today, gracias
      11-01-2016, 08:52 AM   #9
lnxguy
357
Drives: 2009 335D
If you're down 100hp on the dyno, the swirl flaps aren't your problem.
      11-01-2016, 08:57 AM   #10
335dsleeper
389
      11-01-2016, 10:23 AM   #11
Puerto Rican 335d
Puerto Rico
229
Hoping its not the turbos
      11-01-2016, 11:03 AM   #12
dmanb2b
2125
Drives: G07, F97, F30, E90, E46, E30
Sounds remotely similar to what Johnnybravo and Andrew went through and narrowed it down to injectors which felt like no low end boost, even though there was no code present. I'm only guessing and hoping that is not the case for you!
      11-01-2016, 12:34 PM   #13
Puerto Rican 335d
Puerto Rico
229
I just added a bottle of SEA FOAM in my car went for 5 mile spin, I concur with you dmanb2b it might of been injectors clogged, car is running way better cause as i step on it my traction control now comes on before that it wasn't doing that. Gracias
      11-01-2016, 03:31 PM   #14
lnxguy
357
Drives: 2009 335D
Wonder if you got a bad tank of fuel?
'09 335D
      11-01-2016, 03:43 PM   #15
Puerto Rican 335d
Puerto Rico
229
Inxguy i buy diesel from the Shell gas station every week i doubt it but could of been
      11-01-2016, 06:05 PM   #16
Poosik
23
Drives: BMW 335D
PR- hope its something simple man!
Maybe check/replace fuel filter??
      11-01-2016, 07:55 PM   #17
JOHNNYBRAVO1
NY BRAVEST
47
Drives: 2010 Monaco blue, 335D
I'd say INJECTORS. My injectors were my issue and there wasn't 1 trouble code that ISTA could find. It sucks there 400 each and a pain to get out. But it woke the car like it's new.
      11-02-2016, 06:53 AM   #18
MasterC17
329
Drives: 2015 BMW M3
What plugs are you replacing? Glow-plugs aren't going to affect running after start-up.
      11-02-2016, 08:39 AM   #19
dmanb2b
2125
Good to hear!
      11-02-2016, 11:00 AM   #20
Puerto Rican 335d
Puerto Rico
229
MasterC17 swirlflap plugs from AArodiriguez. Car is running better but I need to flor it, traffic has been hell down here with all the rain , need to do a long distance run to clean out, I emptied the whole bottle of SEA Foam in the car we'll see what happens
      11-02-2016, 11:50 AM   #21
BB_cuda
BB_cuda's Avatar
765
PR, we have a couple threads going here sort of in parallel. Did you say you were getting the carbon cleaning while intake is off for swirl flap blanks? If so, can you get pictures of the ports please? Thanks
      11-02-2016, 01:49 PM   #22
Puerto Rican 335d
Puerto Rico
229
Will do amigo BB_cuda. my mechanic has the walnut blasting but does not hv the part to clean Diesel intake, he will contact the local BMW dealer since the head mechanic is our racing friend to see if they can loan us the part. but i will keep everyone posted ok
