How to find latest software revision for AT + ECU?
10-31-2016, 05:47 PM | #1 |
50
Rep 283
Does anyone know how to find the latest software revisions for my X1 35i transmission and ECU?
Are there updates from BMW periodically? How would one know the zusb to flash? For example, I used to have the Alpina flash, but went back to the stock zusb listed in the article. But, isn't this a very old software revision, and perhaps it isn't even the one my X1 shipped with from the factory? Thanks in advance |
11-02-2016, 05:46 AM | #2 |
469
Rep 1,536
This PDF gives you the status of BMW software updates: BMW I-Level Versions
The latest for your car would be E89x-16-07-505, which comes with "ISTA P3.59.2" otherwise known as "SP Daten 59.2". Once you have those software update files you can then just use WinKFP to flash the latest module updates. There is a handy tool available elsewhere on the internet called "ECU Finder" which will give you the latest ZB numbers. You can then look at the 0da and 0pa files and see if they are recent. |
fiehlsport49.50 |
12-21-2016, 10:18 AM | #4 | |
Ballin' out of control.
520
Rep 1,289
http://www.etkbmw.com/bmw/EN/vin/decoder/online/ I'm also assuming that you flashed your EGS module with ZB number 7601492. If either of the above assumptions are incorrect, let me know. ZB number 7601492 is very old. It was released on 02/19/2009. Furthermore, it was never qualified for your X1 X35i. The latest EGS flash qualified for your chassis type is ZB number 8612308. It was released on 11/22/2012 and is applicable to integration levels E89X-11-03-501 to present (E089X-16-11-500). If you found this information useful, please click on the Appreciate button at the bottom of this post.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
fiehlsport49.50 |
12-21-2016, 07:58 PM | #5 | |
50
Rep 283
