M2 Technical Topics > Suspension | Brakes | Chassis > M2 ground control camber plate settings
      10-25-2016, 10:11 PM   #1
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
Ordered some camber plates from GC. They have 3 or 4 fixed camber settings. Can someone tell me the camber at each setting. For example:
Setting 1=stock
Setting 2=stock-x degrees
Setting 3=stock-y degrees
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      10-26-2016, 01:49 PM   #2
rwalker
330
Drives: the wheels off
I'm pretty sure GC plates have continuous adjustment... Also, have you asked GC for those specs?
rwalker@rwalker.com (I really dislike Private Messaging)
      10-26-2016, 04:06 PM   #3
Pyrat 2
Pyrat 2's Avatar
1418
They have fixed setting for the M2. Awaiting to hear back from them.
      10-26-2016, 06:55 PM   #4
DrKevM5
DrKevM5's Avatar
2274
Drives: G05 X5, F87 M2
I have them. They are not fixed. Infinite adjustments within fixed range.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
      10-26-2016, 07:15 PM   #5
Pyrat 2
Pyrat 2's Avatar
1418
Thanks. was just talking to the gcontrol guys on the phone. Ind misinformed me. They mentioned you. Will send you a message separately.
      11-07-2016, 09:31 AM   #6
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
What's the max negative camber you can get at stock ride height?
      11-08-2016, 08:51 PM   #7
Twt
Twt's Avatar
634
Drives: 2017 M2
I installed them last week...set to neg 2.5 and tracked at AMP and Road Atlanta.
The shop says the GC plates can go to neg 5 at the extreme.
      04-10-2017, 06:19 PM   #8
Leduardol
14
Drives: BMW M2
It seems like the most common setting for track is -2.5 camber
Is anyone DD their M2 with camber plates? If so, what are you setting it to for DD?
      04-10-2017, 08:15 PM   #9
Pyrat 2
Pyrat 2's Avatar
1418
Yes. Running -2.5 here too.
      04-10-2017, 11:09 PM   #10
Wangspeed
51
Drives: BMW M2
I have Vorshlag, not GC. Also running -2.5 front camber, 0 toe. -1.7 rear camber.
      04-11-2017, 05:45 AM   #11
rjn
44
Drives: 2017 M2
-2.75; 0 toe
      04-11-2017, 11:57 AM   #12
f87chas
45
Drives: M2
rjn--how is tire wear across the tread with those settings? What do your have the rear alignment set at and how is wear back there?
      04-11-2017, 01:13 PM   #13
rjn
44
Drives: 2017 M2
Looks terrific so far. A little over 1500 miles total (950 highway down/back, ~300 track miles).
They really look good. I'd've taken a picture, but there was nothing to see!
As for the rear, around -1.6 or so. Stock as delivered, and just left it there with a tad of toe in. Running the stock staggered PS2s, the rears seemed to hold up fine.
      04-11-2017, 10:00 PM   #14
CosmosMpower
2051
Does more negative camber change clearance between the tire and the strut? Or does the relationship stay the same? Right now I have just enough clearance on the inside on the stock alignment
      04-11-2017, 10:43 PM   #15
Wangspeed
51
Drives: BMW M2
Pretty sure it would not. That should only be affected by your wheel size and offset.
      04-12-2017, 06:36 AM   #16
Pyrat 2
Pyrat 2's Avatar
1418
No change with adjustments to camber.
      04-12-2017, 08:05 AM   #17
rjn
44
Drives: 2017 M2
Nope. My max camber is currently limited by the stock spring to the inner fender well. I left a pinky finger's clearance. With 60mm springs, I could get even more from the plates if I wanted.
      05-15-2017, 04:11 PM   #18
CompetitionMotorsport
CompetitionMotorsport's Avatar
60
Drives: 2015 M4, 2016 M2, 2017 M2 PE
We installed GC plates on one of our M2's. Everything else was oem. We could get up to -4.5 degrees in the front. We set the front alignment to -3.0 degrees camber, zero toe and max caster. In the rear we ended up at -2.0 degrees camber and zero toe. Car was rock solid under heavy braking and tire wear was even inside to out on a set of Hoosier R7's (265 front 295 rear) on 19" Forgelines after 250 track miles at Road America.
      05-18-2019, 02:40 PM   #19
VegasM2
86
Drives: 2017 M2 LBB/Manual/Exc.
I have GC plates installed but the most they're able to get is -2.2 deg. Am I or my shop missing something?
2017 M2|LBB|Manual|Executive Package|Fabspeed SportCat|Dinan S4 Tuner w Big Turbo|Remus Exhaust|Dinan Intake|Dinan Intercooler|Dinan LPFP Upgrade Kit|Ultimate Clutch Pedal|BMS Clutch Stop
      05-18-2019, 03:43 PM   #20
Twt
Twt's Avatar
634
Drives: 2017 M2
Time to look for another shop.
m2
