Bmw Cowl Filters
10-25-2016, 05:40 AM | #2 |
623
Rep 3,198
Drives: E92 325i MSport Coupe
No experience, but they look like the internals of a K&N air filter - in which case I'm sure they'd work fine.
What put me off going this route is that there appears to be no solution for where to put the two under-bonnet sensors that UK cars have. I think one's for the alarm and one for bonnet closure. When you remove the OEM cowl moulding, you loose the sensor mounting points...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
10-25-2016, 05:48 AM | #3 |
46
Rep 505
That's exactly what I was wondering. I purchased these ages ago but they are currently still in the package they arrived in as I don't know where to put those two sensors.
If anyone has any ideas please post here thanks. |
10-25-2016, 07:56 AM | #5 |
2341
Rep 3,542
This was discussed a month ago in full depth detail.
http://www.e90post.com/forums/showthread.php?t=1303828 |
BMW Steve114.50 |
10-25-2016, 09:23 AM | #9 |
623
Rep 3,198
Zip tied to what? Have you actually seen the sensors we're talking about? They include a push button and need a firm, secure base to operate.
10-25-2016, 09:47 AM | #10 |
115
Rep 968
10-25-2016, 09:54 AM | #11 |
41
Rep 823
daily driven without the cowl for 5 years now had the cowl filters on ever since they were release (3.5? years ago).. car washes.. florida rain.. northeastern u.s. snow - 0 problems.
tuck the sensors. done. there will be some additional noise from the engine bay since the cowl isn't there to muffle |
10-25-2016, 10:11 AM | #12 | |
115
Rep 968
10-25-2016, 11:12 AM | #13 |
181
Rep 1,681
Sorry, didn't realize the UK model might be different (googled the sensor and maybe that one could be zip tied to the strut bar). On the US model, there are 2 sensors on the cowl and those can easily be zip tied.
FWIW, it will be louder with the filters installed. You hear the intakes more. I wouldn't worry about water either, been through a lot of rain storms and car washes and no problems. DME box is sealed. One downside is that you basically have to run your AC all the time as the air coming in will be really hot since these filters get air directly from the engine bay. When you're moving it's ok, but if you're idling at a traffic light the incoming air is very warm unless AC is running. |
10-26-2016, 12:56 AM | #14 |
448
Rep 3,312
I have the filters installed (and the forges etc can certainly be heard much more - which I love lol).
No issues with how they work and as for the sensors and drainage, well I sorted this side perfectly by fitting the M3 cowling. Looks completely OE of course and means everything is in place as it should be (without having anything tied out the way etc). Check out my thread and you should see pics.
E92 335i / M3 Hybrid - The Build
10-26-2016, 03:13 AM | #15 | |
115
Rep 968
I had heard some thing about using the M3 cowling, tried looking for your thread but cant find it. Also is there a part number ? |
10-26-2016, 04:22 AM | #16 | |
448
Rep 3,312
The Build... And post number 445 gives the part numbers for the cowling too You do need to extend the sensor wiring to relocate it and I used some washers to lift the bonnet switch to the correct height for it to make contact with the bonnet. Post number 517 also gives the part numbers for the cable tidy pieces I also used to neaten the whole job. HTH, Raj
10-26-2016, 04:32 AM | #17 | |
115
Rep 968
10-26-2016, 05:05 AM | #18 |
46
Rep 505
so without spending loads more money on M3 cowling where can we move the bonnet senor so that it still operates as if it were still in its original position..?
10-28-2016, 09:45 AM | #21 | |
115
Rep 968
Well, all the bits arrived today, Raj, thanks for the part No info, now all I need to do is get it sorted on sunday. |
10-28-2016, 10:13 AM | #22 | |
448
Rep 3,312
Just realised did you get the 3 bolts required for the cable tidy piece to screw it to the cowling? Can't remember the part numbers. The cowling reuses the existing screws etc.
