10-24-2016, 06:20 PM | #1 |
288
Rep 864
OIL COOLER - Comfort vs Sport Mode
So I bought a Bluetooth OBD2 reader and have the ability to run a dashboard of simple gauges on my phone. Actually, I purchased a Verizon predaid phone for $30 but just never activated the Samsung phone. I just use it as a monitor. similar to Torque app.
. Anyway, what I have found is that the Sport & Sport + modes activate the oil cooler vs in Comfort mode it does not. Oil Temp today with the outside temp going to work in comfort mode was 50degf. AT 50deg and going 80mph on the interstate I saw oil temps running 210-230deg. On the way home with outside temps of 80deg , I was running high 220 range and switched from Comfort to Sport. Oil temp starts to drop about 30seconds after the switch and drop to around 175-185 deg range. . I switched back and forth and it is really amazing how much of a drop there is in Sport mode. Comfort as high as 234 deg vs Sport in the low 170 deg range. Surprising that the oil cooler is not simply activated by oil temps but by mode. Just as interesting is that in Comfort mode and over 230deg that the oil cooler never kicked in but I am betting over 235deg the oil cooler by-pass is activated. I wonder if the oil pressure drops when going thru the oil cooler -- my program does not show oil pressure -- darn. |
10-25-2016, 09:50 PM | #3 |
583
Rep 1,117
Drives: 2015 BMW M235i
I noticed this as well. I thought it makes good sense as to why it happens though.
10-26-2016, 06:29 PM | #4 |
288
Rep 864
Sport Mode on Hot Shut-down
So you are coming to your destination -- Hot Day and drive. It probable makes sense to put the car in Sport Mode (if not already) for the last 5min of the drive to help cool things off before shut down.
. On the interstate I drive in Comfort while in town I drive in Sport / Sport + . . |
10-26-2016, 08:44 PM | #5 |
1424
Rep 3,395
10-27-2016, 11:38 AM | #6 |
157
Rep 580
The gauge works great. It's amazing how long it takes the coolant to reach actual operating temp and how it changes as I drive. As opposed to the usual damped gauges that go to the center quickly,at a much lower temp, and never move.Having it installed, makes me drive more conservatively longer. Being able to see the oil temp is even more valuable.
The major downside is only seeing one reading at a time and, more importantly,not being able to scroll backward. To get back to the previous reading you have to scroll through all the readings back to the beginning. If you don't buy the gauge already installed in a new vent,it's a little tricky removing the two top slats in the old vent and replacing them with the gauge and then reinstalling the two bottom ones.But the rest of the installation is straightforward. But overall, I would buy it again, unless I decided to pop for the very nice and very expensive Awron gauge. |
10-27-2016, 11:45 AM | #7 |
5546
Rep 5,366
Although I have not watched oil temps by driving mode, I routinely drive around in Sport/Sport+/DSC Off and my oils temps are routinely in the 220-230 degree range in normal around the town driving and have seen as high as 240 degrees just after moderately hard driving. In hard driving, the temps have never exceeded 245 degrees. Once my oil temps are above 210 degrees, the temps seem to hold there in city driving. In highway driving, it's typically 195-205 degrees.
My car is a 6MT. Stock. |
10-27-2016, 11:49 AM | #8 | |
463
Rep 957
The air / oil cooler is not activated, the dme is just rating the speed of the water pump For the aux radiator. There are 2 aux radiators, one is coolant, which uses a heat exchanger to cool oil, the other is just an air cooled radiator full of oil, this one has the mechanical thermostat. When the thermostat opens for the other one there is no change in oil pressure as the cooler is filled with oil. The thermostat is mechanical, not electrical. |
10-28-2016, 03:40 PM | #9 |
1753
Rep 2,942
Your dual aux radiators, by model, are:
228i = both are water M235i = passenger side is water, driver's side is oil I have NO IDEA if this has changed for the B-series engines. Let's assume that they are the same. During the time I was researching this issue way back in 2015 on behalf of my car and everyone else's, a buddy dug up information buried deep in the tech manual for the N20 on target operating temps. What we found was very interesting: In the four driving modes that our cars have, the target operating temperature goes down an average of 5-7 degrees F for every mode change from Eco Pro to Sport +. No, 'down' is not a typo. Basically, our engines are designed to run cooler as the engine mode selected becomes more sport-oriented. This is likely to offset greater loads on the engine and is likely the main reason cars with THP (an option on the 228i, and standard on the M235i) in the U.S. get the second aux radiator -- and why any convertible, no matter which model and market, has only one aux radiator. I've observed the operating temp differences with the P3Cars gauge I have in my 228i. The difference is less pronounced in oil temps vs. water temps, but it's there. I can only assume that the N55/Bxx engine in the M235/M240 needs extra oil cooling to achieve those BMW operating temp targets.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
