10-24-2016, 03:22 PM | #1 |
25
Rep 43
340i xDrive Dyno Questions
Whatsup guys, this is my first post here: I have a 2016 BMW 340i X Drive fully loaded and so far my mods are:
JB4 (Running Map 1) BMS Intake ER Catless Downpipes 4.5 Inch Muffler Delete Attached is my Dyno from today, I was expecting a lot more HP, can anyone tell me why it was so low? If it was a Dyno thing or something? Just a little confused haha. Let me know! THANKS! |
10-24-2016, 04:28 PM | #3 |
70
Rep 170
Did you get a baseline on the same dyno, by chance? I wouldn't worry as much about your numbers being low (due to variability between dynos and conditions) and worry more about getting the most out of your DP and tune.
FSociety3811.50 |
10-24-2016, 05:32 PM | #5 |
25
Rep 43
10-24-2016, 07:40 PM | #6 |
1171
Rep 969
What numbers were you looking for? Looks reasonable to me. You know these numbers are measured at the wheels and not crank like factory ratings?
Most on here use STD correction factor. You would have likely gotten slightly higher numbers... something around ~360whp/420wtrq |
10-24-2016, 08:37 PM | #8 | |
25
Rep 43
10-24-2016, 08:37 PM | #9 |
25
Rep 43
No I didn't, what exactly do I need to log it? And it's Auto. Torque is definitely there, I was expecting HP to be right around there as well.
10-24-2016, 08:52 PM | #10 |
18
Rep 72
JB4 can log. Just a thought as your low-mid range is great but after 5k everything seems to plateau and or fall off. I'm curious to see if your losing boost up top for some reason.
10-24-2016, 09:22 PM | #11 |
94
Rep 262
Drives: 2013 BMW 335i M-Sport
Drivetrain loss from xDrive. Search other xDrive dyno runs on xDrive 340's.
10-24-2016, 09:35 PM | #13 | |
1171
Rep 969
Like I said earlier... it reads slightly higher then SAE correction. You may have squeaked out 360whp which is by no means something to frown upon. As long as the car is pulling nice I wouldn't get so worked up over it. Another thing is the gear it was dynoed in... do you know what gear they used? Best to use the gear that is closest to a 1:1 ratio... i think that's either 4th or 5th on the autos, but I don't think the results will vary much based on my friends dyno in different gears... they were all pretty close to one another. Torque is there... horsepower slightly low. Would have been nice to get a baseline. If it bothers you that much.. You can always jump on another dynojet for comparison... though they are pretty accurate across the board. Burger Motorsports did 379/378 on stage 1 jb4.
FSociety3811.50 |
10-24-2016, 10:34 PM | #14 |
25
Rep 43
10-24-2016, 10:36 PM | #16 |
25
Rep 43
10-24-2016, 10:39 PM | #17 | |
25
Rep 43
10-25-2016, 12:57 AM | #18 |
707
Rep 1,170
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
10-25-2016, 03:41 AM | #19 |
Rep 105
Hi,
Don't worry about the numbers. I have a 340xi myself, with a tune, DP and exhaust. I am pulling 100-200km/h in 8.8 seconds (on the speedometer). Before the mods, it took me 11 seconds, which makes a decrease of 25% resp. 25% increase in power. You should find similar numbers. Cheers
F30 340i xDrive - NoLimit PCU - ER catted DP - Lightweight Exhaust System - 19x8,5 ATS Superlight - Bilstein B16 PSS10
10-25-2016, 04:56 AM | #20 | |
2070
Rep 2,639
10-25-2016, 07:27 AM | #21 |
IG @bmwF9xG80
3812
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
What gas are you using ? (TopTierGas 93 is recommended for consistency)
Switch your jb4 to map0 or 4 for baseline run What mode was your car in (Dsc off) what gear ? 4th or 5th ? I see they're using SAE which is fine and its aligned closer to Uncorrected which is what the car made that day, but if you want to brag use STD Smoothing 5 since that shows the inflated number.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-25-2016, 07:29 AM | #22 | |
25
Rep 43
I might do some more runs this week both with the JB4 Off and On, and I think im gonna buy the bluetooth kit so I can log it on my phone etc. They put it in Sport + so DSC was off, And I'm not 100% sure what gear they used, I think 4th or 5th but don't quote me on that. |
