10-24-2016, 01:45 AM | #1 |
25
Rep 97
creaky armrest
Do any of you guys have issues with the armrest making creaky noises whenever it is pushed side to side, usually from lateral forces when turning. it sounds like it is creaking from the spring hinges. Do any of you guys experience this noise? If so what are some fixes. I plan to take the armrest off and inspect. Any how-to's on how to take the armrest off?
10-24-2016, 07:26 AM | #2 |
134
Rep 144
I never had any issues with noise, but I did replace the armrest. I posted a DIY which should help you with the removal.
http://www.2addicts.com/forums/showthread.php?t=1248736 |
10-24-2016, 11:06 AM | #3 |
5554
Rep 5,372
Yes, mine creaks as well, but only when in the extended position. The sound is coming from the plastics of the armrest housing when the sliders are fully extended and the housing torqued by weight. You'd have the disassemble the thing and add felt tape to plastic pieces that are rubbing and causing the creak.
I've looked at the armrest and it doesn't appear to be exactly straightforward to disassemble. |
