Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Chuffin 335d Remap RFT...
      04-04-2008, 07:57 PM   #1
335DJim
335DJim's Avatar
Drives: 335D Coupe
Just look what the remap it did to my RFT's!!.... its a tire shredder quite literally.. heard a flapping noise and bits came off following an enthusiastic pull out of a slip round - damn this cars quick
Anyway - went for the Goodyear Asymmetric F1's as per the autocar review:
http://www.autocar.co.uk/VideosWallp...=228551&Mode=B
- The ride quality alone is significantly better than run flats - all the crashing and bumps are gone, no longer do I grit my teeth approaching small pot holes/bumps. Too early to comment on grip/traction yet (done 6 x miles so far) but the tyre noise is drastically reduced as well. Best way I can describe it is it felt like I was driving on the rims before and now I have the tires inflated!
Here's the tread of the Aysm F1's if anyone's interested:
Sorry pics are crap - camera phone..
I got mine from Pneusonline.co.uk - they have to be shipped from Netherlands cause Goodyear/Dunlop UK has no stock yet..
Cheers,
Jim
Jim
      04-05-2008, 02:36 AM   #2
julesman
Fembots... Mmmmm
julesman's Avatar
Drives: Soon: E93 335i -SGraph\Jade G
Will be ineteresting to see what life you get with same driving style. I've heard anecdotal reports from coupla friends that they dont last long at all... tho they both have heavy right feet. And with that torque... you're gonna EASILY destroy tyres if you use the torque. Let us all know how u get on...
      04-05-2008, 03:02 AM   #3
CD
gone ... but i will be back !
CD's Avatar
England
62
Drives: 335D Coupe
mine are pretty much shot now and only after 9k (4k of which remapped)
pretty expensive habit too these back tyres
E92 335D / QUAIFE LSD / EIBACH / DIMISA / REMAP / 19" HAMANN EDITION RACE REPS
... USUALLY WITH A HEALTHY SPLATTERING OF GOOD OLD YORKSHIRE MUD ...
      04-05-2008, 06:14 AM   #4
RichardM
England
133
Drives: G21 M340i LCI
How many miles did your tyres last and did you replace all 4?
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport
      04-05-2008, 06:14 AM   #5
mikem
83
Drives: Z4M
Look forward to hearing your views on the new F1`s Jim, I found the previous F1`s great.
      04-05-2008, 07:05 AM   #6
hmi1750
hmi1750's Avatar
25
Drives: M135i
I have those tyres on my 18" wheels.
Ride is much improved over the RFTs and the handling is ver good indeed. The tyres grip very well in dry and wet and don't seem to be wearing too badly.
      04-05-2008, 07:05 AM   #7
335DJim
335DJim's Avatar
Drives: 335D Coupe
Rears made 22k (was an ex demo as well!).. yeah I replaced all 4 x with F1's none run flats
Conti RFT 235 35 19's fronts had 4 or 5mm left on them - are they worth anything?
      04-05-2008, 11:42 AM   #8
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Jim, are you contantly drifting out of junctions etc?
Carlos
997.2 GT3
      04-05-2008, 11:55 AM   #9
335DJim
335DJim's Avatar
Drives: 335D Coupe
Carlos
No, just turned the traction thingy off to see what it was like - knew the tyres were going to be replaced so thought what the hell.. didn't expect it to shred the tyres though.. they were down to the tread wear marker I suppose..
One thing I have noticed is the inside wears quicker than the outside because the car 'squats' down on the suspension under hard acceleration..
Got some interesting thoughts on these new tyres V run flats - will post in a day or so when I've got a few more miles on them (60 x so far)
      04-20-2008, 12:34 PM   #10
Terza
Drives: E92 335d
So, can we get any feedback on these tires? I'd be very interested...
      04-20-2008, 03:17 PM   #11
335DJim
335DJim's Avatar
Drives: 335D Coupe
Yeah, OK...
The plus points:
  • Much less road noise
  • Better grip - more so on uneven surfaces or where you get a surface camber or road join (rubber ridge)
  • Much improved feel in the wet
  • MUCH smoother ride
The negative points:
  • You can feel the tire wall flex under heavy load when cornering or hard accelaration out of a junction - used to it now though, you get no less grip you just feel the rear end step out everso slightly when you boot it. I am running circa 340BHP map though..
  • You loose a 'little' bit of the steering directness (again due to slight tyre wall give)
Summary - If I was haulin arse round the Ring in the dry all day I'd stick with the RFT's to be honest (for the feel) on the near perfect surface - for every other eventuality I'd go for the Eagle F1's any day. They just handle our roads better.
Hope that helps you out..
Jim
      04-21-2008, 07:45 AM   #12
330cdsport
Right Responsible
330cdsport's Avatar
58
Drives: AW F21 M135i
Thanks for the update. I will probably go for the F1's in due course as well. Still a few more thousand miles left of crashing and banging on the current rfts though.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
