M57 Injector Removal
10-23-2016, 11:47 AM | #1 |
329
Rep 984
So, any ideas? Here's where I'm at.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
10-23-2016, 11:56 AM | #2 |
389
Rep 1,623
10-23-2016, 12:18 PM | #3 | |
329
Rep 984
Success! A sledge hammer helped "pop" them out!
10-23-2016, 03:06 PM | #5 |
765
Rep 3,556
I recall a forum member doing something along the lines of threading onto back of injector with a slider hammer like apparatus. Sometimes I find it easier to goggle to find things on here rather than do inside the site searches. I'll try this.
10-23-2016, 03:57 PM | #6 |
Rep 106
I did injector #1 on my car, all I did was remove the retaining nuts off of the retainer plate, then use an E-6 external star socket and tighten that stud up, it will force the retainer plate up and take the injector with it, I have over 100 miles and it was super easy to get the injector out
10-23-2016, 04:05 PM | #7 |
24
Rep 110
I used a lug nut that I ground two sides of flat and a slide hammer with jaws. I was surprised at how much force was needed. I was also surprised at how dirty the hole for the injector was.
10-24-2016, 10:18 AM | #8 |
213
Rep 2,210
Im surprised how much rust those fuel feed line nuts get on them. What are they made from? Just generic black steel? Even here in CA where rust doesnt exist on cars my feed line nuts are rusting.
10-24-2016, 01:56 PM | #10 |
22
Rep 109
10-25-2016, 09:24 AM | #11 |
Rep 19
One of the comments from the video was pretty interesting:
"Here's the best and easiest way to remove these stuck injectors (without any special tools): You take the engine covers off, and loosen the two nuts that hold the injector in place. So you should have like 3-4mm between one nut and that metal plate that holds the injector. Do the same for the other nut. Now start the engine and let it idle. While the engine is running watch the injector and listen carefully. When you see the injector shake a bit and also hear a tapping noise, it means that the engine popped the injector out. You can also feel the injector jumping 3-4mm if you put your hand on it. You can also rev the car a bit (under 3500rpm) or take the car for a little ride (if the injector is stubborn). It is best that you stop the engine after the injector pops, because you risk ruining the thread under the bolts. Although you risk ruining the thread, it never happened to me and I have removed many injectors using this procedure. So as the engine warms up and the metal expands, it loosens the grip on the injector, and the engine's compression pops the injector out. Don't forget to grease the injector with graphite grease (which withstands high temperature, white color) when you put it back. Best of luck!" |
10-26-2016, 06:21 AM | #12 | |
329
Rep 984
10-31-2016, 03:00 PM | #13 |
31
Rep 130
When I pulled mine non of them were 'that bad'
a big factor is getting a penetrating oil into them. dry o-rings do not like to move, esp when there is crud around them. I soaked mine in Kroil, then they all popped out with a mini slide hammer I fashioned together. |
11-08-2016, 10:44 AM | #15 |
74
Rep 1,689
I made a DIY here on how I did my fuel injectors:
http://www.e90post.com/forums/showthread.php?t=1290545 Hope people find it helpful!
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5 Once upon a time... '03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T |
11-11-2016, 02:51 PM | #16 | |
329
Rep 984
08-29-2018, 07:42 PM | #18 |
211
Rep 433
Yes it is!
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
