DPF delete pipe with Cat
10-23-2016, 09:23 AM | #1 |
22
Rep 74
Hey guys,
Newish to the forum. After searching and browsing I couldn't find a whole lot of information about this, but is anyone running a downpipe with a cat add on? I'm back and forth on whether it'll make a difference in smell etc. What's everyone else's experience been with diesel smell after deletes? It's the downpipe plus cat option http://www.fixmyvw.com/bmw-335d-dpf-delete-kit-3/ I will be doing EGR race pipe/DPF downpipe/SCR gutting out/2.5+ tune over the next few weeks. |
10-23-2016, 09:58 AM | #2 |
12
Rep 123
If you want an awesome straight through exhaust check out P&L. Very high quality with excellent fitment and works well with the BPC stage 2.5, as they told me.
10-23-2016, 10:02 AM | #3 |
Rep 44
My 2 cents, because I'm going to make that decision soon also. I have a 2005 Passat diesel with EGR deleted, and it has a cat.
It smells like a diesel, if you're idling or in the garage running, so a cat won't eliminate that. I don't know if there is a difference between a cat and nothing at all, but I bet the smell is the same. |
10-23-2016, 10:07 AM | #4 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
there was a long thread on this topic. I'd have to find it again.
Basically the consensus was, removing the doc resulted in a lot of diesel smell and its bad enough on some cars that folks can't drive with their windows down. Also removing the doc significantly increases turbo whistle and exhaust noise. The benifit of removal being some small increase in hp and lower potential egt, but no one to my knowledge has measured the impact. Most just remove the dpf and doc, a few here are running a doc with no dpf and seem happy with the results. Personally, I have run catless cars, and I wouldn't do it again. When I remove my dpf, I will get one with a doc. The reduction in noise and stink is worth it to me for the small if any trade in hp. The high flow doc that buzken sells in their dp may opt affect power at all. |
powellrm22.00 |
10-23-2016, 10:24 AM | #6 | |
22
Rep 74
I'm just wondering if the extra $200 for the cat will be worth it. Cheers |
10-23-2016, 10:31 AM | #7 | |
22
Rep 74
raw diesel exhaust..."THAT'LL PUT SOME LED IN YOUR PENCIL KID". |
10-23-2016, 01:07 PM | #8 |
12
Rep 123
When you are sitting at idle and driving at low load you shouldn't be smokeing the place up. I would hope the exhaust purchased would have excellent sealing capabilities where the smell would be negligible. Maybe I am just being overly optimistic.
10-24-2016, 10:12 AM | #9 |
213
Rep 2,210
Not smoke, raw exhaust smell. Sealing quality of the exhaust has no affect on the smell that is sent out the tailpipe. When sitting at idle even though it all goes out the back it quickly disperses through the area and you can smell it in the car. Its a good reminder of how bad driving in traffic is for you.
10-24-2016, 12:12 PM | #10 | |
22
Rep 74
Cheers |
10-24-2016, 12:14 PM | #11 |
22
Rep 74
The $200 cat with downpipe worth it? Anyone have that Buzzken set up or a set up with the optional cat? I err towards yes.
Thanks everybody |
