The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Hoersepower and torque Question
      10-22-2016, 11:41 PM   #1
Searcher
12
Drives: 2011 335d MSport
After reviewing the different "off-road tunes" available for the 335d I have chosen to go with the BPC stage 1 for now which should be 300whp and 470lbft at the wheels, which is basically the same thing as the 2016 Alpina D3.
My future goal for the car is 500whp and 700lbft. I know the DCT transmission will hold the power based on tuned M3/4's currently. Are our transmissions capable of holding this type of power?
Here is what I think I will need to change to achieve my goals:
HPFP
injectors
hybrid turbos
Intercooler
4" full exhaust
Transmission and torque converter upgrade
I look forward to your thoughts
      10-23-2016, 12:25 AM   #2
Torqu3
321
Drives: 2011 335d
BPC stage 1 isnt an "off-road tune". It keeps all of the stock emissions equipment in place. That is, the EGR, DPF, and SCR. If you have plans to go that big, why not just jump straight to a stage 2+(deletes EGR, DPF, and SCR), and throw on a better exhaust while you're at it? There is no way you are going to get to those numbers on the stock emissions setup anyways.
      10-23-2016, 12:45 AM   #3
Searcher
12
Torqu3...I appreciate everything you have said and I agree with you. The reason I didn't make the jump is that I would like to bundle that step all in one. The existing hybrid turbos I have seen do not have the airflow for what I would like to achieve.
Secondly, the stage 2.5 tune is only 50whp and roughly 100lbft at the wheels more than stage 1 and I would be spending money I don't need to currently as my car runs flawlessly.
      10-23-2016, 07:31 AM   #4
335dsleeper
389
Drives: 09' 335d 10'35D
Id give it some time. In reality, tuning has been the limitation. For instance, my stock turbos made 383/600 at the tire. My remote hybrid tune was based off of my stock turbo tune. Now, Bob @ BPC is making 430/640 with stock turbos. Similar to what he made with hybrids more than a year ago. There has been tuning break throughs that will result in huge hybrid turbo gains.
Hold off for a bit, there are a few guys running hybrids now and with refined tuning, I don't see 500/700 @ the tire being impossible. That said, if you're wanting big power, I highly recommend a fully modified hybrid, meaning hot and cold modification to the LP turbo.
Best of luck.
      10-23-2016, 10:15 AM   #5
Searcher
12
Best of luck.
I fully agree with everything you've said. I think the major limiting factor for whp is the larger turbo is to choked off and could really use a much larger hot side. I have been thinking about finding some broken ones and sending them to Blouch Turbo and let him do his magic. Lastly, I really wouldn't mind a 500whp and 600lbft set upto help save the transmission.
      10-23-2016, 09:52 PM   #6
Got_Diesel
20
Drives: 335d
We do not have DCT transmissions like the M3/M4's. We have a conventional 6 speed auto made by ZF. 6 gears, lock up torque converter in every gear.
      10-24-2016, 12:24 AM   #7
Searcher
12
I know we don't have the DCT. It would be a really nice upgrade since they have them in Europe on our motor.
