Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > DPF/SCR delete with stock exhaust?
      10-22-2016, 02:07 PM   #1
JTC1
36
Drives: 2011 335d
I'm hopefully going to be getting a tune in the next couple of weeks and am trying to weigh my options. Going to definitely get the SCR coded out but leave it in place, but can't decide whether to leave the DPF or spend the extra money and go ahead and replace it with a downpipe and leave the rest of the exhaust stock. Anyone running with this setup?
      10-22-2016, 03:06 PM   #2
335dsleeper
389
Drives: 09' 335d 10'35D
I recommend you search as this has been discussed a few times. Removing the DPF requires removal of the SCR due to soot build up.
      10-22-2016, 03:07 PM   #3
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
+1 on sleeper's point.
      10-22-2016, 03:11 PM   #4
rulonger
111
Drives: 2011 335d E90 & 2010 328i E91
Look for a "clean tune" thread posted by QUIKDZL
http://www.e90post.com/forums/showth...hlight=Quikdzl
Last edited by rulonger; 10-22-2016 at 03:42 PM.. Reason: Add link to another post
      10-22-2016, 09:51 PM   #5
JTC1
36
Drives: 2011 335d
Ok, thanks for the link. I did some searching but did come across what I was looking for. There is some good info in that thread.
I'm getting the P20EE code so I want to tune out the DEF system (leaving it in place) but it sounds like I need to keep the DPF until I decide to replace the whole exhaust and do complete deletes on the DPF and SCR. I'm just not ready to invest $3000 in it right now.
      10-23-2016, 09:12 AM   #6
powellrm
22
Drives: 2011 335D/2010 Golf TDI (RIP)
You can delete the DPF and run the SCR, but I wouldn't recommend it for very long. It ends up putting a lot of strain on that system, which will clog up. You can always gut the SCR.
      10-23-2016, 10:02 AM   #7
Searcher
12
Drives: 2011 335d MSport
JTC....I am in the same boat you are. Just get the stage 1 tune for now. It is 300whp compared to 330whp for stage 2 and it costs so much less. If there is nothing wrong with your systems, don't spend the money....I can't wait to drive the car at 300whp and 470lbft it is going to be a blast for sure....
      10-23-2016, 07:43 PM   #8
JTC1
36
Drives: 2011 335d
Yeah, that's probably the route I will go, but I'm prolly going with JR Stage 2. Not everything is working perfectly as I have the P20EE code which I am guessing is a clogged urea injector. I'm hopping to at least have the DEF system tuned out which would eliminate any future DEF system related codes. The DEF system was replaced on my car right before I bought it and I've put 4,000 miles on it and am already getting codes related to it, so I don't have a lot of faith in it at this point.
      10-24-2016, 12:25 AM   #9
Searcher
12
That makes sense.
      10-24-2016, 04:10 AM   #10
Thecastle
307
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
So JR does offer a stage 2 "race" which can tune egr and scr out but leave the dpf intact. This is probably your route since it allows you to leave your components in place and not have the worry of plugging your scr with soot. Not a lot of people run this config, but Andrew from arod has said they have done several this way.
The stage 2 tune for entact emissions systems only allows egr to be disabled/blocked. It's a little confusing since they really have 2 stage 2 tunes. I'm stage 2 2for stock emissions running since my scr is new and my dpf only has 25k mile s on it. You can upgrade later as needed.
      10-24-2016, 10:31 AM   #11
JTC1
36
Drives: 2011 335d
Yeah the stages of the tunes is a little confusing. I am planning on doing just as you have said. Planning on using blockoff plates for the EGR though. I'm at 64,000 miles, and hope to get close to doubling that before I have to address the DPF. At that point I'll go with a full exhaust and pull everything out.
      10-24-2016, 01:37 PM   #12
Dazza335iC
54
Drives: E39 M5, F15 35d
2000 E39 M5 Dinan  [0.00]
2017 X5 35d  [0.00]
The stage 2 tune for intact emissions systems only allows egr to be disabled/blocked. It's a little confusing since they really have 2 stage 2 tunes. I'm stage 2 for stock emissions running since my scr is new and my dpf only has 25k mile s on it. You can upgrade later as needed.
This is the exact tune I have, and I really like it. It's JR's "stage 2" tune, not their "stage 2.5" or "stage 2.5 race". FYI you have to specifically ask JR to make the modifications to the SCR and EGR systems, as they're not normally included, but it works like this: the SCR system is electronically deactivated, and EGR is reprogrammed to run only during warm-up and DPF regens. IMO, this is the best "bang for the buck" tune you can get, because it eliminates the 2 most troublesome emissions systems (SCR & EGR) but requires no new hardware at all. Of course it also comes with the tune, which they claim is roughly +60hp and +80lb-ft, so that's nice too
      10-26-2016, 06:36 AM   #13
335inDe
38
Drives: 07' 335i
It only cost me $750. Downpipe $500 and $250 to install it and cut open the SCR remove it and weld it back.
      10-26-2016, 09:54 AM   #14
Oilburnerfan
Oilburnerfan's Avatar
Drives: 2011 335d Titanium/Blk M-Sport
That sounds like the tune I've been looking for. Not ready to spend all that money on all the deletes just yet. What's this tune cost? I know that you can go al a carte with the JR tune as you add or delete hardware.
      10-26-2016, 11:24 AM   #15
Khedge
Drives: 2011 BMW 335d
I just recently got the JR stage 2 tune with my emission intact. I have the EGR delete pipe but haven't installed it yea. The car runs great and I am enjoying it so far. I only have about 600miles with the tune.
I also have the upgraded Intercooler from ianknown and it is amazing. The boost builds quick and the car just goes. I highly recommend the Intercooler upgrade.
I will soon get the full exhaust and the downpipe, but for now the stage 2 tune w/ emissions is fine.
      10-26-2016, 02:06 PM   #16
Dazza335iC
54
2017 X5 35d  [0.00]
I paid $1000CAD (around $750USD), plus shipping costs for the ECU to/from their HQ.
      10-27-2016, 06:40 AM   #17
Thecastle
307
Drives: F10 550i
2020 BMW X3  [0.00]
If your running stage 2, not stage 2 race your egr like mine is not fully disabled. Is active during dpf regens, so removing it will occasionally throw an ses.
      10-27-2016, 03:14 PM   #18
Dazza335iC
54
2017 X5 35d  [0.00]
I think you're right. EGR comes in handy during at two times: engine warmup and DPF regens. Hence why I like the tune from JR; it keeps EGR active during these two brief but important times, then turns it off. So you reduce soot by 99% but keep the positive aspects, plus you don't need to buy the race pipe, saving $235.
      10-27-2016, 04:18 PM   #19
Thecastle
307
Drives: F10 550i
2020 BMW X3  [0.00]
I can understand the benefit of having EGR active at startup, to help the engine quickly get up to operating temp. Better fuel economy, faster heat and less wear on the glow plugs.
But during a DPF regen it was my understand the stock software closes the EGR. I'm guessing there is something about the way its coded that the EGR needs to activate in order for the DPF regen process to kick off. It might help to keep EGT's from running too high...
It would seem to me that running cold reduces combustion efficiency and creates more soot, and dpf regen which does post injection events to cause more fuel to burn in the exhaust and full throttle, would all be times you'd want the egr closed to reduce soot being cycled in the intake. I maybe wrong here, but it would seem that these times could generate the most soot.
I know there are BPC folks who have the same features.
      10-28-2016, 03:25 PM   #20
Dazza335iC
54
2017 X5 35d  [0.00]
I'm just going by what Jarek said regarding the necessity of EGR for proper DPF regen functionality. I agree that you want higher EGTs for regens, and that EGR lowers EGTs, but I think there's more to it than just that.
      10-28-2016, 07:46 PM   #21
atwal187
atwal187's Avatar
50
Drives: bmw 335d e90 2009
I had my downpipe in with scr in place and worst decision ever , led to my downpipe getting a leak in the flex pipe due to pressure build up , either gut your stock dpf and scr or go downpipe and scr gut at the bare minimum
