2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Heated steering wheel cannot turn it off
      10-21-2016, 09:29 AM   #1
MSG_228i
Drives: 2015 228i
I have a 2015 228i with all the cold weather options including a heated steering wheel which I have very much enjoyed using on cold days.
Well last night I got in my car in the dark, switched it on and the acrid odor of fried electronics filled the cabin. The heated steering wheel defaults to inactive when you start the car, I believe, but it started to heat up immediately and I could not turn it off by toggling the activation switch.
Time to call the dealer for some warranty work. It's a little worrying driving it like this because the wheel gets pretty hot and I wonder if it will cause a big problem on my 25 mile drive to the dealer. Maybe they would come pick it up on a flatbed for me. Ya right when pigs fly.
      10-21-2016, 09:31 AM   #2
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Well you should make sure it's not short circuiting in your steering column and causing something to smolder between your legs while you drive.
There are certain parts of the wheel that tend not to get as hot because of how the coil is designed, so you can probably drive it fine just keep your AC vents blowing on it to counteract the heat.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-21-2016, 11:50 AM   #3
Rayscott
376
Drives: BMW 228ix
Wear a well insulated glove.
      10-21-2016, 03:39 PM   #4
MSG_228i
Drives: 2015 228i
Roadside assistance might be the easiest way for me to get the car to the dealer.
      10-21-2016, 04:20 PM   #5
raleedy
160
Drives: 2016 228i 6-speed
Asbestos mitts.
      10-21-2016, 08:01 PM   #6
orangeglim
345
Drives: 2019 M2C
2019 M2C  [0.00]
I'm interested to know what the issue was once the dealer takes a look at it.
      10-22-2016, 12:23 PM   #7
JChristie
46
Drives: 2016 M235i
I'd imagine there's a fuse you could pull to disable the heating element in your steering wheel until the problem is fixed.
The F22 fuse diagram shows two fuses for the steering wheel (one 5 amp and one 10 amp) but I'm not sure if either is for the heater. I wish the chart used plain language instead of just symbols.
      10-27-2016, 05:17 PM   #8
MSG_228i
Drives: 2015 228i
Thumbs up
Dealer found a fried circuit in a control module inside the steering wheel and replaced it. They said this part usually fails in a way that makes the heated wheel will not work at all. But in my case it was the opposite - it defaulted to always on.
Also replaced my tires in hopes of fixing a 40MPH vibration issue since I hit a huge pothole a few months ago. I had already replaced both passenger side wheels but the vibration remained. With new tires the vibration is gone. I guess the tires were damaged and that set up a harmonic vibration at 40MPH. So nice to have a smooth drive again, like new.
2addicts
